Go Back   RCCrawler.com Bulletin Board > Vendors > TCS Crawlers - The Crawler Store
Thread: Big News!! The RTR Komodo Wheely King at The Crawler Store
Old 08-06-2007, 07:38 PM   #1
TEAM MODERATOR
EeePee's Avatar
Exclamation Big News!! The RTR Komodo Wheely King at The Crawler Store
The Crawler Store Presents the Komodo Rock Crawler/Basher Wheely King RTR
You read correctly, a Ready to Run Rock Crawler!
The only ready to run, out of the box crawler readily available on the market today.
The HPI Wheely King with our Komodo Package 2 and Crawler Add-on installed already.
This chassis kit utilizes most of the stock Wheely King parts which allows us to keep the cost down. Use of a smaller battery pack placed low in the front lowers the Center of Gravity and increases performance. The motor and transmission assembly have been rotated 180 degrees to bias weight forward for better rock crawling performance. The wheelbase is extended to 12.5" for increased rock crawling and bashing performance. This chassis kit crawls great but can also be used as a high speed basher.
RTR Komodo Includes:
4x4 HPI Wheely King (Includes truck, radio system, wall charger, body)
Installed Komodo Package 2 Chassis Kit
Installed Crawler Add-on
The Komodo Package 2 Chassis Kit contains:
Chassis plates (2)
Battery (2/3A 6 cell shotgun pack)
Battery Plate (1)
Extended Driveshafts
Driveshaft removal/installation tool
Cantilever hardware
Servo Extension
Double sided tape
Hook and loop tape
Zip ties
The Komodo Crawler Add-on contains:
85t Lathe Motor
93t HPI Spur Gear
18t Robinson Racing Pinion Gear
RcGuy Diff Lockers for front and rear
$445.00
We also have the Komodo Chassis available seperately.
TCS Komodo Wheely King Rock Crawler/Basher Chassis Kit - Package 1
Package 1 is for the builder that may already have hardware and components they want to use. It includes only the specialized parts from the kit and requires the purchaser to have components like the battery and hardware. If you are looking for a complete package with everything you need for the conversion, purchase package 2.
Komodo Chassis Kit Package 1 Includes:
Chassis plates (2)
Battery Plate
Driveshaft Tool
Cantilever Bushing
$59.99
TCS Komodo Wheely King Rock Crawler/Basher Chassis Kit - Package 2
Package 2 is a complete kit that includes all the parts you will need for the build.
Komodo Chassis Kit Includes:
Chassis plates (2)
Battery Plate (1)
Cantilever hardware
Servo Extension
Double sided tape
Hook and loop tape
Zip ties
$99.99
Crawler Add-on for TS chassis kits
Includes:
85t Lathe Motor
93t HPI Spur Gear
$40.86
Want some videos of this thing in action? Of course you do!!!!
Right Click Save As please.
Like Metallica? Crawling Video
Like The Crystal Method? Basher/Crawler video
Like The Rolling Stones? Basher/Crawler video
www.TCSCrawlers.com
EeePee is offline   Reply With Quote
Old 08-06-2007, 08:17 PM   #2
666
666's Avatar
Looks like a great idea! I like how the servo is up in the chassis, gives it a cleaner look! I'm also amazed how well the stock tires do!
666 is offline   Reply With Quote
You may edit your posts
