Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Graveyard Shift Losi 2.2 Build
Old 05-30-2009, 11:17 AM   #1
Giveaway Kang!!!
TEDROCKZ's Avatar
Default Graveyard Shift Losi 2.2 Build
Picked this thing up yesterday morning and I took it to work with me last night and got er running(Good to be the boss)
This thing is well thought out as far as mounting electronics,batteries and servos. Had a few minor issues with some loose/lack of loctite, but it's all an easy fix.
This thing has some killer steering and the dig as far running around the house has been flawless. Changed out the tires to Cougars, other that it's pretty much straight from the box.
Gonna try to bribe Mayhem into some matching offset wheels as I don't think the little hardware will hold out to long on the stocks ones.
Also got to run down to the race car shop to put the body in the metal brake to fold in the lower sides.
Parts
Spektrum 3520 dsm2 rx
Tekin Fxr
HH 35t handwound w/17t pinion
CC BEC @6.0v
TP1320 and Maxamps1100 3s lipos
Hitec 5955 for now until my new JR8711 gets here
MRC dig servo
Panther cougars
Probably gonna try the Tekin RS system from Holmes next week.
Few pics:
Side by side w/ my berg rig. With the tire set-up I have there is about 5/8-11/16" more axle clearance on the Losi.
TEDROCKZ is online now   Reply With Quote
Old 05-30-2009, 12:00 PM   #2
wow putting it next to the berg u can really see the ground clearance losi did there homework!
punkuup5150 is online now   Reply With Quote
Old 05-30-2009, 12:53 PM   #3
have any issues w/ motor tourqe or feel like its binding. because mine did it has not seen the first rock
hodges996 is offline   Reply With Quote
Old 05-30-2009, 01:01 PM   #4
Truck looks great! And please let us know how the Tekin RS system works for you.
Could you explain this process a little more please? I know Rich said the future ones will come with bent sides, but I am curious how to go about bending the lexan if I ever need to in the future. Thanks in advance for any info you can provide.
jnev is offline   Reply With Quote
Old 05-30-2009, 01:13 PM   #5
Giveaway Kang!!!
TEDROCKZ's Avatar
At first there was some. But with some runtime it seems to be getting better. I took my axles of the truck and chucked the driveshaft half on the axle in a 1/2" drill and spun them for about 10 minutes each after greasing them good.
Just referring to bending the bottom of the body in toward the chassis bout level with the bottom of skid. I just use a sheet metal brake.
Old 05-30-2009, 01:17 PM   #6
How do you actually bend the bottom of the body though? Is there a special process? Or just heat, or...? Thanks in advance.
Old 05-30-2009, 01:19 PM   #7
I'm Dracula, Bitch.
JeremyH's Avatar
Nice work!
Haha....yeah, I work on RCs up at work as well!!
JeremyH is online now   Reply With Quote
Old 05-30-2009, 01:23 PM   #8
Giveaway Kang!!!
TEDROCKZ's Avatar
No special process. Just bend like you would a piece of sheetmetal. In a brake or a vise, wide billed pliers(flatters what I call them). Just clamp it where you want to bend it and it will leave you a straight edged bend. I'll get up a pic or two later.
Edit: notice the pic on your box. It's rolled/bent about 45 degrees or so, kinda gives it a roll pan look.
Old 05-30-2009, 01:27 PM   #9
Hateraide
Code454's Avatar
That Looks awesome ncie and clean body, cant wait to see some action shots
Code454 is offline   Reply With Quote
Old 05-30-2009, 01:39 PM   #10
Sounds easy enough. I appreciate the help.
Old 05-30-2009, 06:39 PM   #11
i sat there for about 20 min watching tv and rolled mine by hand. they sucked in real nice
latentimage74 is offline   Reply With Quote
Old 05-30-2009, 06:46 PM   #12
Hahahahah. .20 min- should take about 20 sec. 'buddy'.
APESHAT is offline   Reply With Quote
Old 05-30-2009, 06:53 PM   #13
Giveaway Kang!!!
TEDROCKZ's Avatar
Further proves my point... Easy to do
Old 05-30-2009, 06:58 PM   #14
quality work takes time sucka!
Old 05-30-2009, 08:07 PM   #15
Rockcrawler's Avatar
Nice Steve!
Cant wait to drive it.
Rockcrawler is offline   Reply With Quote
Old 05-30-2009, 09:13 PM   #16
Giveaway Kang!!!
TEDROCKZ's Avatar
Originally Posted by Rockcrawler View Post
Nice Steve!
We may slip up to Hoover @ Saturday Closet place for me to any good crawling.
May have an inside scoop on getting you one by then(maybe). The LHS owes me a favor
Old 05-30-2009, 09:57 PM   #17
Sounds like a plan.
Especially the last part. Its going to be a tough job to beat this berg though.
Old 06-11-2009, 02:45 AM   #18
I like to #*&^
i just did my body by hand in about 5 mins easy as pie
2500hdon37s is offline   Reply With Quote
