Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: HillBilly HellRazor
Old 05-30-2009, 10:23 PM   #1
hbj069's Avatar
Default HillBilly HellRazor
Losi Comp Crawler
Futabe 4PK
R603FS
Holmes Crawlmaster 1000kv
24 tooth pinion
Mamba Max ESC
Venom 3s 1550 Lipo
Hitech 5645 Steering (Rig is so smooth it just dont need anymore)
Hitech 5245 Dig
Front wheels after weights 12.5 oz
Rear wheels after weights 8.5 oz
LOSI 30wt in front shocks
LOSI 35wt in rears
1.2 quarts of thread lock (Loctite Brand)
Beating Jeff at the next crawl, (PRICELESS)
Well after 20 Hrs of breaking, fixing, adjusting, and changing, I think they built one HELL OF A CRAWLER. Oh well tommorrow at lake Ohatchee LOSI VS BERG.
hbj069 is offline   Reply With Quote
Old 05-30-2009, 11:11 PM   #2
Rockcrawler's Avatar
It can be done for the right price...................
Rockcrawler is offline   Reply With Quote
Old 05-30-2009, 11:14 PM   #3
I like to #*&^
nice sime truck. dang makes me want one! how does it do compared to berg??
2500hdon37s is offline   Reply With Quote
Old 05-30-2009, 11:17 PM   #4
hbj069's Avatar
Its coming!!
Old 05-30-2009, 11:18 PM   #5
hbj069's Avatar
Its the best shafty I have ever seen, But it aint no berg!!
Old 05-30-2009, 11:22 PM   #6
I like to #*&^
i belive its the new trend truck and dang thats gobs of diff clearance!
Old 05-30-2009, 11:26 PM   #7
How is the wheel speed with that crawlmaster?? I have a few of those kicking around..
clarkrw3 is offline   Reply With Quote
Old 05-30-2009, 11:28 PM   #8
hbj069's Avatar
I personally think its gonna need more weight in the wheels, it dont want to settle after front tire crests over a rock. real slow about articulating.
Old 05-30-2009, 11:31 PM   #9
hbj069's Avatar
Its good but it wont do back flips. its as fast as my berg was with the 2 45t's and a 3s lipo. Kinda scared to do much more as forward inertia vs weight vs stopping is gonna put a ton of stress on the worm gears and is gonna be an issue.
Old 05-30-2009, 11:44 PM   #10
Wow!
You gotta a crawlmaster in there?
I didnt think one of those would fit. Did you have to do any clearancing?
I used to have one of those in my old rig and loved it. Think I might have to pick up another one for the new rig.
Also which version of the crawlmaster is it?
Rocksmith Eng. is offline   Reply With Quote
Old 05-31-2009, 12:33 AM   #11
Dream...Think...Create.
Nova's Ark's Avatar
How is the start up with the CrawlMaster? I love brushless outrunners but the low speed / initial start up takes some getting use to. Does the low worm gearing make the outrunner crawl like a brushed motor?
Nova's Ark is offline   Reply With Quote
Old 06-01-2009, 12:39 AM   #12
How's the 5645 working for your rig, I bought one for mine but wasn't sure if it would be enough.
BJoe is online now   Reply With Quote
Old 06-08-2009, 06:54 PM   #13
Hbj069, have you had a chance to get the Losi back up and running, if so how did it perform on the long run?
torn body is offline   Reply With Quote
Old 06-08-2009, 06:56 PM   #14
hbj069's Avatar
works fine untill you bind it up but hey the truck is still broke and the servo works fine!!
Old 06-08-2009, 06:58 PM   #15
hbj069's Avatar
I think its gonna be ok, we had a guy at our comp with one and he let some of the Big Guns run a couple of courses with it and they stated that it had serious potential with minor mods. Hope this helps.
Old 06-08-2009, 07:02 PM   #16
That was Steve (TEDROCKZ). Going to be a nice rig with just a little weight in the front. I pulled a few lines that give some of our guys trouble with it.
I just hope they get the shafts figured out.
Old 06-08-2009, 07:45 PM   #17
hbj069's Avatar
and the big gun just spoke!! Thanks, I didnt want to spit out names, I know how testie you can be!!
Old 06-08-2009, 07:52 PM   #18
I'm no big gun.
Old 06-08-2009, 07:54 PM   #19
Giveaway Kang!!!
TEDROCKZ's Avatar
Pulled this thing down yesterday/today and found no issues... I'm still a believer that the pins slipping out of the cvds is the issue with all the breakage. They don't have to back out very far to come around and hit the axle Cs. Plus the fact that the actual steering on the Losi will turn 5 or so degrees further than the cvds.
Long story short, before you run it the first time check all the pins for tightness and Loctite. Back the steering back 10 percent or so.
As for the comp Sat. it was bone stock out of the box w/exceptions of panther tires w/@ 2oz in each front. As said before a couple of Heavy Hitters run it on some courses and give it some good feedback.
I've owned every dig system that is for sale other than the Eritex system, none so far is as smooth and consistent as the Losi.
Gonna add some stuff they recommended and see where it is next Sat.
Time will tell
TEDROCKZ is offline   Reply With Quote
Old 06-08-2009, 08:04 PM   #20
hbj069's Avatar
you guys are some of the greatest. Thanks
