Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Need Help!!
Old 05-31-2009, 05:56 PM   #1
Default Need Help!!
Ok let me explain what im trying to run, Im using a teken rebel II & a 35 turn lathe with a 18 tooth pinon & an 8 cell split pack's the wheel speed is preaty good but after 5 min of driving in my basement the motor got almost to hot to touch, Im trying not to run lipo for cost reasons!! Any help or suggestions! Thanks Tom!!
sniders1975 is offline   Reply With Quote
Old 05-31-2009, 06:07 PM   #2
Thats how it is, worm gears are inefficient so they will heat that little motor up!
kikcaffine is offline   Reply With Quote
Old 03-25-2010, 05:19 PM   #3
He is correct. Your money may need to be spent on brushless and not lipos. But the worms will eat brushed motors up went through a 35,45, and 55 untill I went brushless and that was the trick. So you may have to cough up the $$ to get it to do what you r lookin for.
Lineman A is offline   Reply With Quote
Old 03-25-2010, 05:38 PM   #4
benoj's Avatar
one thing that will help is drop the pinion several teeth i wouldnt run over a 14-15t on a 35t
benoj is offline   Reply With Quote
Old 03-25-2010, 07:49 PM   #5
Go brushless I had the same problem went brushless no more heat issues.
flipper is offline   Reply With Quote
Old 03-25-2010, 09:26 PM   #6
Old thread
Don't worry, he went brushless about 9 months ago.
kwkride is offline   Reply With Quote
