Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: What are you guys doing about adding weight to the wheels
Old 06-01-2009, 12:06 AM   #1
Default What are you guys doing about adding weight to the wheels
What are you guys doing for wheel weight?? Are you adding your own? or does Losi have something for this??
Happy_trucker is offline   Reply With Quote
Old 06-01-2009, 12:34 AM   #2
Who's your Daddy-0!
TattooKenny's Avatar
Looks like the channel in the wheel is to small for the lead weights we use normally. You would need to cut them in half to fit. There is room on the outside of the wheel for them to fit though. With the CVD prob right now I would be scared to add any weight to the wheels.
TattooKenny is offline   Reply With Quote
Old 06-01-2009, 09:41 AM   #3
Live,Eat,sleep RC
RcBro's Avatar
I ran it without weights and it did rather well
RcBro is offline   Reply With Quote
Old 06-01-2009, 07:35 PM   #4
Thanks guys, I actually shaved the inside channel to fit the weight. Not lead, but a lead subsitute for wheel weight and it worked good. This one was narrower than the regular stick on weight. One strip wrapped around the wheel was 4 oz. Then for the fronts I slap on an extra strip of the regular sized but still lead subs one time around and the total for the fronts are about 7.5oz.
Old 06-04-2009, 06:32 PM   #5
Another option is at the local tackle shop. Look for "stick" led. Here you can find in pre-cut length or on a roll like electrical wire. It's just round lead a little smaller than a pencil that you can roll out and cut to lenght. Wrap it around the rim and back it up with a few wraps of eletrical tape to hold it there
grouser is offline   Reply With Quote
