Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Broken Pinion tooth
Old 06-04-2009, 05:12 AM   #1
Default Broken Pinion tooth
Just wondered if anyone else has broken a tooth off of the worm pinion ? I don`t know when it broke and couldn`t find the missing part of the tooth in the axle , but it was there saturday when it was greased . It seemed to be working fine ,just pulled it down to remove a shim and there it was . Could have broke off due to the sudden stop inherent to worms when getting off throttle , maybe . Something to keep in mind when rolling off a leadge or tumbling down a rock off power, there really is only one tooth fully engaged at any timeon the pinion . I`m going to put it back in and run it till I get a replacement , I can`t hurt it anymore than it is , and it was unnoticeable last time I ran it sunday . I did turn the push control of the FXR on the last run and it worked great on 2 and 4 , any higher than 4 would be too much I think .
By fourbyaddict, shot with Digimax A402 at 2009-06-04
4XADICT is offline   Reply With Quote
Old 06-04-2009, 12:03 PM   #2
Losi Rep
Rich Trujillo's Avatar
WOW now that is one we have never seen. Could you shoot me a PM I'd like to see about getting that one back and send you a replacement.
Thanks
Rich
Rich Trujillo is offline   Reply With Quote
Old 06-04-2009, 12:41 PM   #3
lol it would be nice if every part in the axles were ti :P
some87 is offline   Reply With Quote
Old 06-04-2009, 01:08 PM   #4
Titanium brings it's own set of problems, and isn't a 'miracle' material.
letus is offline   Reply With Quote
