Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: I hate the slipper
Old 06-06-2009, 06:22 PM   #1
Default I hate the slipper
Ive tried to tighten it and it still wont climb anything the slipper wont let it. Who puts a slipper on a crawler. I there a way to eliminate it?
Flyin Hawaiian is offline   Reply With Quote
Old 06-06-2009, 06:23 PM   #2
Axial, and Losi ;)
As far as how to eliminate it...stay tuned, i'm sure someone will find a way...
Crawlow is offline   Reply With Quote
Old 06-06-2009, 06:29 PM   #3
666
666's Avatar
Pull the spur gear out and check the slipper pads for grease or residue. Then make sure the cone washer is facing in toward the spur gear.
Also it would not hurt to pull the axles apart a check the shims. There should only be one shim on each side of the spool, they have been shipping them with 2 which is too much and causes excess heat and drag. The shims themselves are really thin so take them out and pull them apart, it is hard to tell there is 2 so look closely.
666 is online now   Reply With Quote
Old 06-06-2009, 06:38 PM   #4
Rules? What Rules!
Speedracer19's Avatar
You maybe able to pin the hubs & gear together by drilling a hole through the front hub, gear, rear hub & put a roll pin in & that would lock it, but may put a strain on something else.
Speedracer19 is online now   Reply With Quote
Old 06-06-2009, 06:54 PM   #5
I was going to do that but found that the cone washer was bottoming out on the shaft, put a spacer between the cone washer a the outside persure plate. No slipping now.
westsac crawler is offline   Reply With Quote
Old 06-06-2009, 09:00 PM   #6
I removed 1 shim on each side of the spool and it helped but didn't eliminate it completely.
Old 06-06-2009, 10:49 PM   #7
Default glad im not the only one
Sure am glad im not the only one with this problem gonna try out some of these tips made me look bad my buddys axial was crawling circles around me and i could not even get up the front step to his house
roundguy74 is offline   Reply With Quote
Old 06-07-2009, 02:46 AM   #8
Well then....
mann0mann's Avatar
Don't mean to sound like a newb here...but what does it sound like?
I've not heard what I would call a traditional slipper sound coming from my Losi. In fact when it gets bound I feel like the motor cogs and stalls out with a brushless motor.
What I am hearing is what I think is a slip in the drive cogs. Those cogs are under spring tension and I hear a tension "click" when under load now. This will happen in front dig, rear dig or 4wd.
I've taken the tranny apart twice now nothing looks out of order. Have not thought to look at the slipper since the nut is on tight.
mann0mann is offline   Reply With Quote
Old 06-07-2009, 09:39 AM   #9
Losi Rep
Rich Trujillo's Avatar
Try adding a small shim or washer between the aluminum spacer and where it touches the slipper plate.
The tolerances are very tight there and if they missed it (which we have seen with the CV's) you could be bottoming out on the actual slipper shaft end and not the plate. I've seen this in a couple so far.
As for why we added a slipper, it's supposed to be help protect the tranny, but it should not even be noticed when functioning correct.
Thanks,
Rich
Rich Trujillo is offline   Reply With Quote
Old 06-07-2009, 07:29 PM   #10
Default Got mine kinda working right
Well after looking the slipper over and trying some of your ideas as to how to make this work short of just giving up i have since drilled the spacer out so it now slides all the way onto the shaft and used 2 washers from the pack of extras. After looking at my slipper i found that it was bottomed out without putting any tension on the slipper. this seems to have helped quite a bit will get some more testing as soon as the rain stops this has been very frustrating for me.
Old 06-10-2009, 12:12 PM   #11
Location: siloam springs, home of the Mid West Challenge 2010
Sorry if I sound like an idiot but how do you tighten it. I took the gear cover off and tried to hold the gears with my fingers but that worked real well. All it did was spin inside my fingers. Do I need to pull it apart to tighten it? Thanks guys
dustin keeler is offline   Reply With Quote
Old 06-10-2009, 12:21 PM   #12
The slipper nut is exposed - you can get a wrench on it + tighten in the truck-
APESHAT is offline   Reply With Quote
Old 06-10-2009, 12:27 PM   #13
Practicing my launchs >:)
Robbob's Avatar
easiest way i found is put an .050 wrench in the setscrew the slipper nut is on, turn the wrench counter clockwise while holding the nut with some pliers to tighten it. vice versa to loosen.
Ive since redid mine with a long set screw that you find in a Losi buggy slipper, a slipper spring from a 4th generation Associated T4 and a plastic washer. (btw youll need to heat the existing set screw to remove it, they used the Good Loctite on there lol)
Adjusted it to where it started slipping when i hold a foot against, clears the battery tray perfectly and hasnt caused any problems yet. Ill post pics tonight when I start my build thread.
Robbob is offline   Reply With Quote
Old 06-10-2009, 12:57 PM   #14
thanks guys
