| | #1 |
| Rock Stacker Join Date: Feb 2008 Location: thailand
| before i get losi i have rf2.2. (setting hispeed wormgear moter55T ) when i get losi i move all EP. to losi comp motor hot it happen i think because center gearbaox of losi very low ratio(around2.6) rf 2.2 center gearbaox ratio is86/19=4.5 some body know how abount ax10 gearbox ratio (i don't know because just build ax10+r2) what you think about this |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Feb 2009 Location: Grand Rapid
| I ont think its so much the trans ratio as it is the worm gears. It takes alot more work for worms to move the truck. Where as a standard bevel gear rotates freely. |
| | #3 |
| Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
| its the worm gears because they create so much friction it puts more stress on the tranny making it all hot |
| | #4 |
| Rock Crawler ![]() Join Date: Apr 2005 Location: Humble
| Well it's easy to test, just swap in a different tranney. |
| | #5 |
| the tranny that is in it was built for the worm gears other trannys wont work it i beleive |
| | #6 | ||
| Gold Star Baby! ![]() Join Date: Jun 2005 Location: In Kahoots!!!!!
Why wouldn't any other trans work? You would just be going slower. Motor temp would definately drop. | ||
| | #7 |
| Of course other trannys would work...LOL See the problem is Misinformation. I'd like to see a Kyosho RF setup in there or a PTI maybe, just to see how much work the tranney is adding to the motor itself. |
| | #8 | |
| Newbie Join Date: Jun 2008 Location: Germany
the Axial have an overall ratio that can be adjusted from 15:1 all the way up to 74:1 using different pinion/spur gears. The center mounted transmission have 1:2,6. If you use stock pinion/spur the reduction overall is 1:47. On the RF you use 86 spur and 19 pinion (i=1:4.5) and the high speed worms (i=1:15) thats overall i=1:67.5. Your 55 T is getting hot with this combo I think. I run a 21.5 T brushless and overall reduction of 1:100 and this works very good. Take a look on Losis manual - different reduction examples and recommandations. regards Juergen | |
| | #9 |
| Thread Tools | |
| Display Modes | |
