Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Which wheels?
Old 06-09-2009, 08:55 AM   #1
Default Which wheels?
What offset does the LCC use?
Whats everyone else using?
biged is offline   Reply With Quote
Old 06-09-2009, 09:18 AM   #2
Rules? What Rules!
Speedracer19's Avatar
Axial type offset.
I use the Vanquish Revolvers with 3 slugs front & 0 in the rear.
Speedracer19 is offline   Reply With Quote
Old 06-09-2009, 09:53 AM   #3
I like to #*&^
i tried my axial beadlocks and its real close to the knuckle with the bead lock screw
2500hdon37s is offline   Reply With Quote
Old 06-09-2009, 09:55 AM   #4
Pro-line titans fit up nice. No clearence issues.
Dark8ngel is offline   Reply With Quote
Old 06-09-2009, 09:59 AM   #5
Thats only because they are stock width. A narrower axial offset wheel will be just fine. IE. DNA's, Mayhems, Vanquish, oh and DNA's!
bigflex is offline   Reply With Quote
Old 06-09-2009, 10:05 AM   #6
Vanquish you can use medium width adapters in front and Berg width adapters in the back.
wrightcs77 is offline   Reply With Quote
Old 06-09-2009, 11:03 AM   #7
What offset for the Competition Double Phatty rims?
We offer two different offsets in our standard 2.2 style rims.
1st Offset - .443 (11.25mm) this is a negative offset, meaning that the bottom of the hex is as close to the hub side as possible. (see Diagram A) This offset offers a wider track width. Original offset – Wide.
2nd Offset – This offset is .147 (3.7mm) this is also a negative offset. This offset will bring your wheels closer to the frame, this offers a narrower track width of approximately 10 ¼”. New offset – Narrow.
Old 06-09-2009, 12:10 PM   #8
I'm using my Sinner 2's from CAC and they seem to fit nicely. I am running no weight in the rears and 12oz or so in the front. I need to drop it down but i have had a chance to yet. They look good too!
promatchrcr is offline   Reply With Quote
Old 06-09-2009, 09:27 PM   #9
Pro-Line 8 shooters work just right on my LLC.
MISFITCOMPER is offline   Reply With Quote
Old 06-09-2009, 09:49 PM   #10
Vanquish Dirty Harry's with the widest offest up front and narrowest out back. Plus 2 to 3 slugs up front as I am still experimenting, and 0 out back.
bustedcrawler is offline   Reply With Quote
Old 06-10-2009, 06:40 AM   #11
Just got my Axial offset DNA Assains. They look sweet and they match my mini!
T.T. is offline   Reply With Quote
Old 06-10-2009, 07:36 AM   #12
I use this because only one i have
1st Offset - .443 (11.25mm) .
loverichey is offline   Reply With Quote
