| | #1 |
| Rock Stacker Join Date: Apr 2009 Location: nor-cal
| http://www.shopatron.com/product/par...56.35129.0.0.0 i just saw this on novac's website, it's a 14mm rotor for the goat, do you think it'll help cut down on motor temps.i have a 14 tooth with a 2s2p 3300 mah lipo motor get scorching hot and run times of only 32 mins.i've checked the diffs and tranny.same motor w/ 1600 mah in axial would go for 45min. and not get hot at all |
| Sponsored Links | |
| | #2 |
| Latest NorCalRCRC slave ![]() Join Date: Dec 2008 Location: San Mateo, CA.
| The rotor is to help smooth up the low end on the Goat motor, and is supposed to provide alittle more torque. It probably won't do much for temps. I did not experience super hot temps when doing my Goat testing, with 15 tooth pinion. I got about 30 minutes on a 1600mah battery. |
| | #3 |
| Quarry Creeper Join Date: Sep 2008 Location: Kennesaw
| Im only hitting 115 with my EXACT same power train setup |
| | #4 |
| i figured out my temp issuse,it was from too many shims in the diffs and front wheels over tightened.i got 1hr20min out of the goat with 3300 mah losi battery highest motor temp was 145*. i put in the 14mm rotor and raised my pinion to a 18 from a 14 and this thing is bad a$$.tons of torque tons of wheels speed runs forever(got tired before that battery went dead)and never temped over 104* on the motor.so i would say the goat set up with a optional 14mm rotor is a good setup. |
| | #5 | |
| Newbie Join Date: May 2009 Location: fresno
| | #6 |
| the actual nut,it caused the pin to bend into my bearings,causeing drag/friction |
| | #7 | |
| Newbie Join Date: Jun 2008 Location: Socal
| | #8 |
| Does changing the rotor make it not that have jump when you initially hit the throttle? |
| | #9 |
| not sure i never had that problem with the goat setup,with either rotor |
| | #10 |
| When you went to the 18t pinion did you lose any low torque? |
| | #11 | |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
The 14mm rotor is good for increasing torque at a sacrifice to top speed. | |
| | #12 | |
Interesting, why does it lose top speed? Because of more rotating mass? | |
| | #13 |
| yes but it also allows you to go up in pinoin size to regain your speed while still having torque,does more work with less effort |
| | #14 |
| It will do more work with more effort, you don't get anything for free. Power is power whether it is made through rpm or torque. The larger rotor strengthens the magnet field in relation to the windings, which drops Kv (rpm per volt). Any time the magnets get stronger the Kv will decrease. |
| | #15 | |
| if your kv goes down but your getting more torque,wouldn't you be doing less effort to get more+or in other words more effic. Quote:
| | #16 |
| More torque per amp (Kt), but it is at a lower RPM. Power involves both rpm and torque. |
| | #17 |
| ok,well i'll i know is the goat with a 14 mm rotor rocks |
| | #18 |
| | #19 |
| I don't have the losi. |
| | #20 |
| Can I order the rotor from you john? |
| Thread Tools | |
| Display Modes | |
