Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Goat /7 cells
Old 06-11-2009, 07:28 PM   #1
I <3 LS3
exesivefire's Avatar
Default Goat /7 cells
I know the world is lipo crazy right now and for good reason, but has anyone tried the goat system on 7 cells yet?
from what I am reading the goat setup is close, just needs a bit more kick at times.
thoughts?
exesivefire is online now   Reply With Quote
Old 06-11-2009, 11:36 PM   #2
I was thinking the same thing but instead of 7 cells I looked for a more powerful 2 cell Lipo and found this.
http://www.maxamps.com/proddetail.ph...4-Pack&cat=205
Its a 2000 mah 2s Lipo and it has a 60C burst with 30C constant. It is 0.5mm wider than the LCC battery tray but I am sure I can get it to work.
This should give the Goat a little more jam, I ordered one and it got shipped out today, and since I am in canada it probably wont get here till later next week, I will report back then
BCkoots is offline   Reply With Quote
Old 06-11-2009, 11:40 PM   #3
def post up your results,sounds cool
trx310r is offline   Reply With Quote
Old 06-11-2009, 11:44 PM   #4
I <3 LS3
Correct me if I'm wrong, but that is still a 7.4 volt pack.
That pack may stay at peak longer, but without an increase in voltage you probably won't notice a huge change?
Old 06-12-2009, 12:24 AM   #5
It really depends on the quality of the cells. As soon as I get min back together I will throw my 7 and 8 cells in and try it, I am running a 2 cell 2000 at 25c now. Nice meeting you in montana by the way.
Steve
edge540 is offline   Reply With Quote
Old 06-12-2009, 08:01 AM   #6
It is still 7.4V but having a higher peak at 60C and a constant of 30C will allow the battery to drain at a higher amperage. I think it will be a noticable change, but I am still learning Lipos. Will post the results when I have the batt.
Old 06-12-2009, 09:04 AM   #7
I <3 LS3
Steve
Careful on the 8 cells, dont let the magic Novak smoke out
It was good to meet you too bud
Old 06-12-2009, 02:16 PM   #8
This is exactly what I've been planning on trying. My 6 cell pack just doesn't have the umph to get the goat out of a bind. I'm going to try 7 cells when I find a good set of loose batts. I wish the goat system could handle 8 cells....
celsiusprime is offline   Reply With Quote
Old 06-12-2009, 06:22 PM   #9
You can run the Goat on 3s You must use a bec and check that the power cap says 16v not 12v
Old 06-12-2009, 07:16 PM   #10
My documentation says that the limit is 2s or 7 cells. I wish I could run 12v.
Old 06-12-2009, 07:31 PM   #11
Correct, thats what the book says but the system will handle 3s just fine. you just have to clip the red wire and use a bec. I have run mine this way without any trouble.
Old 06-22-2009, 02:26 PM   #12
I just ordered a 7 cell pack last night. Here are the specs:
4/5A size cells
2000mAh
7 cells in series
Hump configuration
I'll post up my findings after I've had a chance to try it out. I'm hoping that the extra cell will be just what the doctor ordered.
Old 06-22-2009, 02:57 PM   #13
Tomorrow, we will be announcing our new Goat 3S controller.
It will include a special profile for the Losi Comp Crawler.
NovakTwo is offline   Reply With Quote
Old 06-22-2009, 03:07 PM   #14
DBR
So any trade in upgrade options for existing owners? *hint hint*
DBR is offline   Reply With Quote
Old 06-22-2009, 03:37 PM   #15
I <3 LS3
that is worth looking into...
Old 06-22-2009, 03:41 PM   #16
Freaking sweet!
kikcaffine is offline   Reply With Quote
Old 06-22-2009, 04:02 PM   #17
perfect. .
APESHAT is offline   Reply With Quote
Old 06-22-2009, 04:22 PM   #18
We were only able to get the LCC vehicle about 10 days ago, so we were in the dark about how to make sure the new Goat 3S would be compatible.
We will also be releasing a 13.5 Crawler motor for our existing 2S controller (for use in the LCC.) The 13.5 motor is too hot for the 3S.
As we develop more guidelines, we will post updates to the BL Crawler system page on the website.
Old 06-22-2009, 04:22 PM   #19
Hey Andy, I ran my goat on 6,7, and 8 cell packs and it seems to build less heat with higher voltage and smaller pinions. Be carefull of packs that have lower c ratings. Mine works the best on 3s lipo although I dont see why you couldnt do the same with a nimh pack with enough cells. basicly you need real low gearing to avoid heating up under a load and enough volts to get some wheel speed. Good luck
Old 06-22-2009, 07:07 PM   #20
Any est. date on when it will hit distributors?
atekt is offline   Reply With Quote
