Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: another cause for heat
Old 06-11-2009, 11:35 PM   #1
Default another cause for heat
after taking out my extra spool shims tonight i found more cause of drag.if you put the front wheels on too tight you will bend the little pins behind the hubs and they will push into the front bearing causing friction,i think this is the cause for my goat set up over heating with a 14t.i was alway tightening them real tight cause i have the vanquish wheels and they don't allow the nuts to thread on all the way.hopefully this might help someone else chaseing a over temp issue
trx310r is offline   Reply With Quote
Old 06-12-2009, 08:05 AM   #2
On the lookout for Rocks
constantmotion's Avatar
Thanks a lot of force on the wheels nuts to bend the wheel pin.....
constantmotion is offline   Reply With Quote
Old 06-12-2009, 08:33 AM   #3
Practicing my launchs >:)
Robbob's Avatar
sounds like your hex screws may have loosened too. those should lock them in place and let you crank the wheel down.
Robbob is online now   Reply With Quote
Old 06-12-2009, 08:40 AM   #4
that's the crazy part ,they were tight.but the pins are really small.one actually broke in half.
Old 06-12-2009, 08:55 AM   #5
ripper7777777's Avatar
Yea, why the hell are the pins so tiny
ripper7777777 is offline   Reply With Quote
