09-03-2009, 05:31 PM | #101 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Nice job Jake. Sorry you got beat by a berg. |
09-29-2009, 07:13 PM | #102 |
Rock Stacker Join Date: Jul 2009 Location: dusty foot path
| Del Monte Can you post up the final set up you had with your Losi at worlds. Tires Weight F/R Motor Pinion Suspension And anything else you would like to add. |
09-29-2009, 07:55 PM | #103 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Awesome Losi Del Monte....Can't wait to get my Losi build done. What's up with those Boss Claws?
09-29-2009, 09:23 PM | #104 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Setup Updates
Here's a little setup update.. I'm pretty happy with the way the truck is handling now. I'll be on the rocks a lot in the new few weeks to get ready for 801RCC's Utah state championships... Winning 3 in a row won't be easy I'll be bringing a few sets of Boss claws to play with on the Utah redrock, but I'm betting that they will be incredible there. I had them out on some damp, cold, sandstone over the weekend, and they hooked up well enough to give me a 30-something point victory I have a feeling that they will do very well in St. George... Upper Links: Top hole Shock Arm: Center hole (B) Shock Mount: Bottom hole (1) Shock Oil: Losi 50wt. http://www.horizonhobby.com/Products...rodID=LOSA5227 Piston: Orange #55 http://www.horizonhobby.com/Products...rodID=LOSA5047 Internal Limiters: none External Limiters: 3/8" Springs: White Rear Suspension Upper Links: Top hole Shock Arm: Center hole (B) Shock Mount: Middle hole (3) Shock Oil: Losi 40wt. http://www.horizonhobby.com/Products...rodID=LOSA5226 Piston: Red #56 http://www.horizonhobby.com/Products...rodID=LOSA5046 Internal Limiters: none External Limiters: 3/8" Springs: Custom... however I've had really good luck running the White springs and running the shocks in the #4 mounting hole. |
09-30-2009, 12:47 AM | #105 |
Rock Stacker Join Date: Aug 2005 Location: australia
Hey Del Monte, just like to say (all the way from Australia) congrats on your placing at worlds and THANK YOU for the great info that you have posted in your thread. i have purchased one of these rigs and i cant wait for it to arrive!!! i will be setting it up to the same setup as you have. i have 1 question for you. with the dx3R you use does the aux channel you use for the dig allow you to use front and rear dig or just rear?? i ask this as i have a dx3S and i have read the instruction book and it will basically only let me have rear dig. keep up the good work Thanks Reece |
09-30-2009, 01:46 AM | #106 |
no talent hack Join Date: Feb 2007 Location: Redwood City
the 3r will let you have both
09-30-2009, 02:19 AM | #107 |
Newbie Join Date: Aug 2009 Location: Denmark
Thanks for the setup, I'll have to try it... About the DX3R, there is no problem running front and rear DIG... Really great radio to a great car... |
09-30-2009, 05:31 AM | #108 |
Ok I looked on spektrums site the dx3.0 has the same 3 rd channel feature of 3 positon as the dx3r so it would be cheaper rather than get a dx3r as I got a dx3s already! What speeds do you run the diffs in on a drill??? |
09-30-2009, 07:17 AM | #109 |
Rock Stacker Join Date: Jul 2009 Location: Munfordville
Im pretty sure the DX3.0 is only a 2 position 3rd channel. You can have kind of a ghetto 3 position switch, using the reversing feature on the controller and the 3rd channel button on/off button. If there is another way, I dont know about it.
09-30-2009, 07:22 AM | #110 |
nah i checked in the manual section in here on page 19 http://www.spektrumrc.com/Content/PD...al-english.pdf |
09-30-2009, 07:29 AM | #111 |
Rock Crawler Join Date: Sep 2008 Location: Utah
Rig looks good! Im excited to see it run in St george, all though the trophy is staying here this year |
09-30-2009, 08:25 AM | #112 |
Thanks Del Monte!! Good luck in Utah!! Are you still at 10oz added to the fronts and 3oz added in each rear wheel? |
09-30-2009, 11:25 AM | #113 |
| Yeah, I'm still running 9-10oz in the front, and 3oz. in the back. If you're in an area that has good traction or a lot of steep drop offs you could probably add another once to each rear tire. My rig performs better with 4oz. in the rear tires, but you can really tell that you're dragging that extra weight when trying to climb slick stuff.
09-30-2009, 11:36 AM | #114 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
Hey thanks Jake for the info. I just Set mine up last night. I just need to change the shock fluids and pistons. Oh and add a little weight to the wheels.
09-30-2009, 12:38 PM | #115 | |
09-30-2009, 12:56 PM | #116 | |
09-30-2009, 01:33 PM | #117 | |
I wish I could have seen you and Brad run too... Once the fog rolled in I lost everybody. That was a cool event though. Are you guys coming to the Socal season opener at Cougar Buttes? We'll have to hang out and BBQ if you guys make it out there | |
09-30-2009, 02:29 PM | #118 |
| Ya the fog was crazy. All the score sheets were really damp and were getting hard to write on. Great night though and Jake your perfect run was awesome. I cant wait to compete with you with my new LOSI |
09-30-2009, 08:12 PM | #119 |
Rock Crawler Join Date: Jul 2008 Location: Hesperia
Tyler, I love your avatar!
09-30-2009, 08:46 PM | #120 |
RCC Addict Join Date: Jan 2009 Location: O.C
| Hey Tyler, I picked up a set of knee pads for you so your comfortable the next time you see Jake |
