06-21-2009, 10:15 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Gold country
| Upgrades for the Losi?
As it stand this crawler is real good but let get some performance upgrades. How about a BTA or plate fore the battery on the axel .I would like to here other idea,s from crawler,s :-P
06-21-2009, 10:20 AM | #2 | |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
I believe RCbro and myself are workin on what your talking about. So far he has come out with a servo plate I have come out with Ti kingpins, turcite steer bushings And I am working on a couple other lil goodies as I am sure RCbro is as well. Stay tuned today as I workin in the shop all day to see what I can come up with. So bta it is | |
06-21-2009, 10:25 AM | #3 |
Ti worms/ That would lower the rotating mass fore faster acceleration |
06-21-2009, 10:31 AM | #4 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
If you look at your Losi the BTA is much more complicated then that of the Axial. The rear link offered on the axial has room! With the mounting of the links and the shocks, there is no true straight portion to work with.. Thats not to say we won't figure something out, but we also wont release junk parts which means we got to have time for testing. I know there are alot of companies trying to be the first with some upgrades. I myself wont rush quality.
06-21-2009, 10:41 AM | #5 |
CKRC already has got the cv,s taken care of that thing looks bomber!! |
06-22-2009, 09:59 AM | #6 |
Pebble Pounder Join Date: Jan 2009 Location: Where you want to be
How about an OTA steering setup, if you cant go thru then how about over?
06-22-2009, 11:44 AM | #7 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
Id like to see a machined tranny center section/ motor clamp to keep everything from flexing under power.
06-22-2009, 12:08 PM | #8 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
| I can't get the damn motor out of the plastic housing, there better be enough play if the machined piece were metal. I can't tell you have many bruised knuckles I have trying to swap out motors |
06-22-2009, 12:08 PM | #9 |
Rock Crawler Join Date: May 2008 Location: carson city
Bent links?
06-22-2009, 12:23 PM | #10 |
Rock Crawler Join Date: Jan 2009 Location: Great NorthWest
under gearing for the rear worm so the front over pulls |
06-22-2009, 08:29 PM | #11 | ||
RCC Addict Join Date: Apr 2004 Location: 5280
Why wait for a battery plate? I already made one in less time than it took to type this, with $0 extra dough for it. Get creative, lots of uses with what you got laying around... Quote:
No, I would vote for something else. Ti while sweet is a bad choice for worms. I'll have to dig up the materials on the last gearset I worked on, but when I inspected them they had still had a ton of life left after 40 years of use. 15HP motor, and 20,000 lbs on the winch drum. IIRC, and I will have to double check, the spool was a soft 10XX series carbon steel and the worm was a high strength bronze... I THINK. I have the prints on the desk at worm calling it out. Much like a Losi axle, those winch boxes were PACKED with a moly based lube. | ||
06-22-2009, 10:28 PM | #12 |
| Use a small dab of associated black grease in the motor cam's slot. Thats what I used to have to do to my losi xx-4 race buggys. You may want to check to make sure there's no molding flash on the tranny center section that would cause the motor mount to be overly tight.
06-22-2009, 11:28 PM | #13 | |
06-23-2009, 01:28 AM | #14 |
Newbie Join Date: Nov 2008 Location: F1 1st Night Race
was wondering, how are the centre driveshafts holding up for you guys? Are they made of alu or plastics? I hope they are not as fragile as the AX10's.
06-23-2009, 09:07 AM | #15 |
Don,t worry the driveshafts are not a problem!! |
06-25-2009, 05:04 PM | #16 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
| Wait till next week or so. DNA will be coming out with some cool stuff I'm sure.
06-25-2009, 07:26 PM | #17 |
VROOM VROOM the race is on :-P
