07-22-2009, 01:12 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: The County Hell
| front axle forward issues...
45 T Integy, 15 t pinion FXR esc,7.4 lipo, whole drive terrain sounds loud... going up a steep incline the rig binds down going forward... same incline in reverse flawless, broke in worms...cleaned regreased both axles, updated CVD's engaging dig helps for a second then binds up again... any help appreciated:-( thanks The Pig Bandit |
07-22-2009, 02:06 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Check links etc... Mine was making some binding noises yesterday when I was out testing some tiny packs (3s 600s) and placement... the noise was only in forwards, and only when there was weight on the rear. I did notice that last time I ran it as well on Saturday that I had some noise coming from the rear end only when under a load, but not as bad as yesterday. Turned out on the rocks I didn't notice it with a few quick looks, but once I got home and blew the dust off I noticed I had broken one of the LCA's at the axle side. It was pretty bent, my guess it had bent over a week ago in a big fall and I didn't notice it till it snapped yesterday and really started to bind up. Just something to look for. Check yoru links, arms etc, and make sure they are all straight and not causing binding by pulling the axles and driveline out of square. |
07-22-2009, 02:34 PM | #3 |
maybe your drive shaft angle
