09-03-2009, 08:54 PM | #1 |
Pebble Pounder Join Date: Apr 2009 Location: somewhere
| not happy
i have spent a ton of money on my lcc and it still dont work right eveytimie i think i have it solved there is something else i just put in a tekin brushless system with a 13 tooth pinon also tryed a 17 tooth but the pinon slips on the spur when it is under load and not much of a load at that i put it over as far as it well go and it slips the slipper clutch is tight and i am now at a loss spent all this money on what something that just sits there i think it is in the transmission i replaced the spur even though the gear looked ok so someone tell me what the problem is im to the point of never buying a losi product again and making sure that anyone that plans on getting one dont sorry but i have had it |
09-03-2009, 08:59 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Holy punctuation! I had to read that 4 times to try to understand your message, and I'm still not completely getting it. What exactly are you stating or asking here?
09-03-2009, 09:12 PM | #3 |
im trying to figure out why the motor/pinon slip on the spur gear i cant get it any tighter and the slipper clutch is tight cant get it any tighter plus a new spur gear so now what
09-03-2009, 09:30 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: NorCal
Sorry for your troubles,,,,, but I think your in the wrong hobby,,,if you don't have the patience to work thru a set up you will always be frustrated with crawlers. There is plenty of help here and MANY others have gotten the LCC to crawl like a stripped ape. So calm down and take a breath and go thru the posts and track the problem down one thing at a time eliminating all possibilities untill you get it running,,,,,,,,,,,,,,,,,,,,,,,,,,
09-03-2009, 09:31 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Just to get it straight, your Pinion is not slipping on the "Spur" gear. If you were having gearmesh issues your plastic Idler gear would be toast, all stripped out, very visible damage. What you're having a problem with is the Slipper clutch. You said you've tightened it down as much as it will go and it still slips. There was a few posts about the slipper clutch not getting assembled properly, or wrong spec parts or something like that (search this forum for posts by Rich and slipper). Here I did the search for you: I hate the slipper Read the thread, and the post from Rich. |
09-03-2009, 09:35 PM | #6 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
09-03-2009, 09:42 PM | #7 |
well first of all im calm second i have this thing a little over 2 months and still havent ran it much maybe an hour total trying differnt motor set ups ill check the idler gear it does make alot of noise i seen somewhere on here about the spring on the slipper clutch so back apart it goes
09-03-2009, 10:18 PM | #8 |
Pebble Pounder Join Date: Apr 2008 Location: bfe
09-03-2009, 10:25 PM | #9 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
I'll solve your prob for ya.....I'll give ya $150 for it right now Take it and solve your problem! See how easy that was? Seriously, look at the slipper and the tranny. Prob will be in there somewhere.....or take the $150 |
09-03-2009, 10:28 PM | #10 |
This is a long shot, but make sure the set screw for the pinion is tight.
09-03-2009, 10:30 PM | #11 |
RCC Addict Join Date: May 2009 Location: NHFF world headquarters, working on the "rock mauling hill shooting NHFF pig squealing death rocket"
09-03-2009, 10:30 PM | #12 |
09-03-2009, 10:42 PM | #13 |
nope its tight im not a newbe to rc's hell forget super im thinking jb weld
09-04-2009, 06:09 AM | #14 | |
Now here is a nice somple way to set the gear mesh. If you want to use a 13T then take a 14T and put it on the motor. Now lock down the motor plate with the 14T meshed as tight as possible. Remove the 14T without loosening the motor plate and replace it with the 13T and you will have an almost perfect gear mesh. Also it would be nice if you would use punctuation and capitals when you write, it does make it easier to understand for the rest of us. | |
09-04-2009, 06:22 AM | #15 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
I don't have an LCC but couldn't something inside the trans be broke or bad. Trying to help |
09-04-2009, 06:23 AM | #16 |
Also it would be nice if you would use punctuation and capitals when you write, it does make it easier to understand for the rest of us.[/QUOTE] This is the best idea so far. |
09-04-2009, 07:48 AM | #17 | |
I've stripped three idlers so far. Once when the pinion gear I was using split by the set screw, once when I didn't follow my own advice and set the mesh right and finally the third time was in a big bind and the slipper was locked tight. I put in a new idler and adjusted the slipper so it only slips in an impossible bind and all seems to be good now. | |
09-04-2009, 07:52 AM | #18 | |
This is the best idea so far.[/QUOTE] On the other hand Mesooners could be from a country that doesn't use English. I thought he/she was from Oklahoma (Sooners). | |
09-04-2009, 08:03 AM | #19 |
09-04-2009, 08:24 AM | #20 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Wow. After some of the comments on this thread it's no wonder people get turned away. Does the guy need to use punctuation? It wouls sure make it easier but we're not in grade 9 english class. I'd probably be frustrated as well. And when you get frustrated you tend to over look something simple. Give the guy some help or just shut the hell up. I agree with AreCee. Probably the idler gear. |
