10-04-2009, 09:10 PM | #1 |
Rock Stacker Join Date: Aug 2005 Location: australia
| Aussie LCC
hey all well i finally received my LCC today i opened the box and i was amazed with the crawler.. um i dont have any electrics yet as im getting them next week, but ill be running HH35t or integy 35t mamba max esc 1250mah 2s lipo dx3s radio have not got a servo picked out yet. ok so i have read through alot of the threads here and taken in all the tips and tricks to break in the diffs and so on. How ever i noticed that when i opened the box there was no extra cvd's just LCC and stickers and few spare screws and instruction booklet. now im A, thinking it already has the revised ones fitted or B, they got left out? Can i tell this by the batch number? if so is it the number on the tranny/dig unit? which that number is (RC-003481) any help would be a greatly appreciated thanks Reece |
10-05-2009, 06:19 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
You can tell by looking at the CVDs.. The slot for the pin was cut with a saw and extends the cut into the axle too far. There are pics here in one of the threads.
10-05-2009, 04:37 PM | #3 |
thank you for the info ill have a look for the pics and check mine. would any one know what type of servo arm i could use on a CS-170 servo??? |
10-05-2009, 05:33 PM | #4 |
10-05-2009, 06:02 PM | #5 |
thank you AreCee for the info greatly appreciated.
10-05-2009, 06:37 PM | #6 |
Rock Crawler Join Date: May 2008 Location: carson city
10-05-2009, 07:26 PM | #7 |
10-09-2009, 03:17 AM | #8 |
10-09-2009, 02:24 PM | #9 |
Quarry Creeper Join Date: Apr 2009 Location: Israel
Looks good. good gears, slanted to the right & everything. Not been on the rocks yet huh? I can tell cause the body is lower than the skid(will drag on the rocks & make that horrible noise). I like the simple yet effective paint job. |
10-09-2009, 02:46 PM | #10 |
id go with the holmes hobbies 35t if you can and a 13t-12t pinion if you can
10-09-2009, 02:52 PM | #11 |
thanks big boss, yeah it has not yet been on the rocks its still in bits, im waiting for my CKRC 35T Hand wound motor, cs-170 servo, novak fan, 13t and 15t pinions and a packets of the axial shock dampers to arrive, will be using some marine grease or i have this liebherr slew ring grease so i might use that for the gears...
10-14-2009, 07:11 PM | #12 |
well got my stuff today CKRC 35t motor, novak fan, shock dampers and i now have 12,13,14,15 and a 18tooth pinions will start with 12 and see how it goes. will get motor and fan mounted then ill pack some grease in the diffs this time next week when i get back from work with the slew ring grease.. and hopefully all should go well.. also i need some help with my mamba max esc. i dont know if the drag brake is turned off and my computer has windows vista, i tried to upload the castle link software but it wont work. I have read the manual programming section in the booklet but im a bit confused and from what i gather i wait for 5 beeps to access the drag barke?? then i give it full throttle to say yes and then wait for another beep to say no drag brake and select yes again to turn it off??? can some one please help me out here as i dont want to screw it all up by not turning the drag brake off.. Last edited by Greasterman; 10-14-2009 at 07:44 PM. |
10-14-2009, 10:31 PM | #13 |
Quarry Creeper Join Date: Dec 2005 Location: SLC
A little off topic but is there much of a crawling scene down under?
10-14-2009, 10:34 PM | #14 |
The latest CastleLink software works fine in Vista... I'm running it both in Vista and Windows7.
10-14-2009, 11:22 PM | #15 | |
i just went to the castlecreations web and downloaded the latest version and got it all set up now. Last edited by Greasterman; 10-14-2009 at 11:48 PM. | |
11-01-2009, 02:02 AM | #16 |
well i put the losi completely together today CKRC 35t motor with a 15t pinion, Mamaba max esc, hobbico cs-170 servo i cut the bottom of the body a bit instead of bending it. im not running a dig servo as i need to get one.. i ran it with a stick pack ontop like the std ax10 as i dont have a big enough lipo for a good run, i got over an hour out of a 3000mah NIMH!!!! with more to go. Will be getting a bigger 3s lipo in the next month or so.. carnage was only stripped out the alloy servo horn that came with the losi now have a plastic one on there hopefully it will hold till i get another alloy one.. got a few bind/stalls but nothing major and no other damage. motor got warm but i could touch it and the diffs got about half the warmth of the motor. let me know what you think.. i drove into this and out of it i was so amazed , cause the stick pack is on the top too!!!!! all of the rocks are in my back yard too.. |
11-01-2009, 03:43 AM | #17 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
Nice back yard!
11-01-2009, 07:00 AM | #18 |
Quarry Creeper Join Date: Jul 2008 Location: Alexandria
I wish I had that backyard. Try a 4s lipo like 1300mah or something close. That is what I am going to try if I can't get my 3s/FXR/35t combo to quit smokin.
