which wheel offsets for vp dh procomp's hey guys i was woundering whats a good setup for wheel offsets for the losi using vp dh procomps? |
I just picked uo a set dh's and Im going to get one set of each and play with them. It'll be wider in the front of course. I just need to find some wheel nuts that will allow the nylock engage. |
I run 4 wieghts in the front and 2 in the rear. Seems stable and planted. |
I run the wide ones front and rear with 4 slugs in the front and 2 in the rear pretty stable on all lines."thumbsup" |
ok i think your asking about offset. i run 585 ft and 460 rear with the dh procomps |
I run the same as billygoat 585/460. the 460 offset is pretty much the same as stock. I run 4 slugs front and 3 rear. here is a view from the top. you can see the difference between the kingpins up front. stock on left and vanquish on right. http://i403.photobucket.com/albums/p...90/topview.jpg |
yes the offset thanks"thumbsup" |
i run the widest offset in the front middle offset in the rear 3 slugs in front none in the rear,works great |
