11-04-2009, 07:15 PM | #1 |
Pebble Pounder Join Date: Apr 2009 Location: somewhere
| end points
i have bought the the spektrum dx3.0 does anyone else have this radio and if so how did u set it up for the dig im having problems with the end points and getting the set any ideas well help thanks
11-04-2009, 10:20 PM | #2 |
Newbie Join Date: Jun 2009 Location: Vacaville
| I have mine set at about 30 and 35, just follow the destructions in the losi manual. It says to start with the ball cup about 2mm from the rear of the dig case.
11-06-2009, 04:24 PM | #3 |
Quarry Creeper Join Date: Nov 2008 Location: Orange
With the DX3.0 are you only runing one dig? Front? Rear? |
11-07-2009, 08:35 AM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: Lake County
| Run both!
I had the same radio allready,and I can use front and rear. Make sure when you set up your dig servo that it's servo horn is centered,then make sure to adj your end points so your servo dosn't strip,or burn up. You can reverse the AUX direction while driving to change the dig frt,rr.
