Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Metric conversion?
Old 02-05-2010, 08:46 AM   #1
Default Metric conversion?
I know this is an odd task and the more I think about it it likely doesn't exist but have any of you heard of a metric harware kit for the LCC? I know all the thread bodies are SAE but it would be nice to use my spendy hex wrench set on the LCC. Any other hardware kits avail?
jmike is offline   Reply With Quote
Old 02-05-2010, 09:54 AM   #2
spend some more $$ and get standard drivers..... it will be less of a head ache down the road! you will spend almost what you would on a screw kit and none of the screws will fall out...... (shouldn't)
rugerboy is offline   Reply With Quote
Old 02-05-2010, 08:17 PM   #3
Any quality hardware replacements?
Old 02-12-2010, 12:00 PM   #4
oh great the LCC has standard hardware? :-( All of my crap is metric. I have tons of screws for backups and its all metric. Is the hardware at least allan or do they use a lot of phillips? I can stand phillips on rc equipment. Please tell me that isn't the case.
hellacool is offline   Reply With Quote
Old 02-12-2010, 01:54 PM   #5
It's all wrench heads..The 4-40 stuff never fails..I put lost of 3mm rod end and
3mm bolts in axles and stuff...I ended up going back to 4-40.
fa1rch1ld is offline   Reply With Quote
