02-16-2010, 10:39 AM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Florida
| Driveshaft set screws...
Any good tips on gettint the set screws out on the axle end? I have allen wrenches that are either a hair too loose, or won't fit at all... the allen key I used for the servo screws, and all the other set screws is a 1/16 inch. I have the new gears, but cannot replace them... HELP.:-(
02-16-2010, 11:03 AM | #2 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
1/16" should be the correct size for those set screws. Maybe try a little heat on them to help break them loose.
02-16-2010, 11:37 AM | #3 |
yeah, tried heat, no good. At least once I split the axle the gears are the correct ones, the back weren't, so i guess I got lucky for now... I'll just get some better tools, and an easy-out just in case...
02-17-2010, 10:33 AM | #4 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
I have a couple of quality hobby based wrench sets, but I ended up having to pick up a T handle 1/16" wrench from lowes to bust the shaft grub screws loose when I got my truck. Whatever kind of threadlock the asians are using on these things is almost impossible to get off. I HIGHLY recommend taking all of the metal to metal hardware off and cleaning all of the threadlock off and starting over with blue lock-tite.
02-17-2010, 11:12 AM | #5 | |
Quarry Creeper Join Date: Jun 2009 Location: Winchester
