02-18-2010, 08:42 AM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Tucson
| LNC issues...HELP!
So I am totally new to the whole RC thing and I have been loving my LNC. I haven't been able to find any other info on here with the same unique situation I have. I am all stock except for 6oz front, 3oz rear wheel weights with prilone epic wheels, and proline chisels. I have had it for a couple of months now and it seems like my performance has gone downhill. I am running a 7.2V NiMH stick pack because I can't afford to go Lipo right now. It seems like I run out of torque quicker than before now and it gets bound up in the rocks in high traction situations way easier than it used to. I am wondering if my motor is on it's way out??? If it was weaker would I lose torque quicker while the battery runs down? The advice I need from you guys is what motor/pinion combo would work best for me running the NiMH battery. I would like more wheelspeed than stock but I want the torque so I don't bind up so easily. |
02-18-2010, 08:58 AM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Florida
LiPo's are cheap... http://www.hobbycity.com/hobbyking/s..._(DE_Warehouse) or http://www.ckrccrawlers.com/shop/ind...oducts_id=2227 How many charge/discharge cycles have you gone through, and do you completely discharge the NiMH before you recharge? They can get a memory... Does your charger show you how many mA your battery takes during a charge? |
02-18-2010, 09:03 AM | #3 |
Holdin my 40oz. Join Date: May 2008 Location: Somewhere in Colorado
You wont be able to get more wheelspeed than stock and still get the torque you need to not stall the motor, it's just not possible. I would drop about 2-3 teeth off of what comes stock with the chisels, as their added size puts more stress on the motor. Or drop a tooth off and go back to the stock tires. Unfortunately, that's the best advice I can give you. Upgrade to brushless as soon as you can afford to, and you'll be happy cuase you'll get both wheelspeed and torque.
02-18-2010, 09:52 AM | #4 | |
I'll have to look at my charger, I haven't done much other than just charge them up and go! Ill sit down and really look at it tonight! | |
02-18-2010, 09:55 AM | #5 | |
02-18-2010, 11:11 AM | #6 |
Friend uses this charger with no issues... http://www.hobbycity.com/hobbyking/s...lancer/Charger I use this charger... http://www.hobbycity.com/hobbyking/s...(USA_Warehouse) I just modded an old computer PSU to give me the 12VDC supply... My charger more than handles the demand that I put on it keeping batteries fresh for 2 crawlers. |
02-18-2010, 01:39 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
nickel metals DO NOT have a Memory and as far as your situation about torque drop your pinion like 3 teeth and that will help with lack of torque and such.............pm me your address and ill send you a 2 cell lipo for free if you have a lipo charger |
02-18-2010, 02:22 PM | #8 |
| PM sent!
02-18-2010, 04:09 PM | #9 |
Pebble Pounder Join Date: Nov 2009 Location: Utah - Rocks Are EVERYWHERE
So if I send a PM do I get a lipo for my night crawler? I have the charger:-P
02-18-2010, 04:46 PM | #10 |
Newbie Join Date: Jan 2010 Location: Comstock Park
Why don't you just spend $35 and get a better motor like a integy 35t or 45t. Will be a world of difference. If you put a different motor on it you can also elimnate the capicators if your using a lipo.
02-18-2010, 06:19 PM | #11 |
Rock Stacker Join Date: Sep 2008 Location: cumbria
i had the same problem it turned out to be the motor so i swapped it out for an infinity 35t hand wound motor on the standard lnc pinion and using 2cell lipo has made a huge diffrence paul |
02-18-2010, 06:36 PM | #12 |
02-18-2010, 08:13 PM | #13 |
Newbie Join Date: Jan 2010 Location: Lebanon
35T motor will pull more amps and turn more rpm's, so take the extra wattage the 35T can produce gear down slightly and you have alot more torque
02-18-2010, 09:16 PM | #14 | |
It is still highly recommended to treat NiMH the same as a NiCad to prevent memory. Most battery manufacturers recommend a complete reconditioning after 10 cycles. | |
02-19-2010, 06:24 AM | #15 |
Cause the stock motor is a piece of junk. It helped in my rig.
02-19-2010, 06:59 AM | #16 |
I pulled it out last night and ran in a little bit. I would only take about 10 minutes on a full battery to start losing power where I couldn't climb up anything even with one tire. This happened once before where all the sudden I couldn't climb a steep rock face, I changed the setting on the ESC for a few minutes, then changed it back and it was fine after that. Do you think the ESC could be faulty???
02-19-2010, 09:27 AM | #17 |
Pebble Pounder Join Date: Oct 2009 Location: Rapid City
I know that my LNC ESC is bad, I am getting a different problem (superficial binding) and have tried 3 different motors with no sucesses. I am upgrading to brushless.
02-19-2010, 09:34 AM | #18 |
Pebble Pounder Join Date: Jan 2010 Location: Moses Lake
My brother in laws LNC has been experiencing the same problems that have been discussed. He just recieved his new motor so hopefully that will help for him. I also noticed his would bind only when it was articulated to the max. I had him put some spacers in the shocks to limit some of the travel and it help as well.
02-20-2010, 12:10 AM | #19 | |
Newbie Join Date: Aug 2009 Location: san jose
i cant wait till castle fills the orders on the mamba max pro... Last edited by four12unner; 02-20-2010 at 12:13 AM. | |
02-20-2010, 12:12 AM | #20 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
same happened to me ;) its your battery |
