02-21-2010, 01:22 AM | #1 |
Newbie Join Date: Dec 2009 Location: hillsboro
| DIG servo problems on my LCC!
OK I have the DX3E radio and adjusted the epa's on the aux channel for the dig unit...I just fried my 2 DIG servo....first a digital hitec mini servo and now the analog after about 2 minutes....and i was even using the dig...ran the dig a few times to make sure it was working and then back to 4wd...I run the castle bec pro set to 6 Volts....WTF????
02-21-2010, 08:53 AM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Dearborn Hts
Check your end point adjustments.............
02-21-2010, 09:51 AM | #3 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
End points are extremely cruticial. I normally set the travel on my dig so it just barely engages the dig, but still engages it evertime without any binding noises. I've also found personally that hitecs don't like the LCC
02-21-2010, 10:03 AM | #4 |
Newbie Join Date: Feb 2010 Location: Fort Walton Beach
with the dx3 i noticed that you have to work the dig multiple ways to shut off the servo or it will sit and wind even will not being used
02-21-2010, 11:10 PM | #5 |
Ok...What DIG servo should i buy...Dont want to mess around with cheap servos...What's the best? money doesnt matter at this point as long as it will friggin work...Haha...
02-21-2010, 11:19 PM | #6 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
If the EPA's are not set correctly it wont matter if you put in the most expensive servo out there....it will fry also. I've been running Hitec 85MG mini units in two LCC's for well over 6 months with no issues. I also set up 2 team mates with the same unit and they too have been running for 6 months without issue. As everyone is saying, make sure the EPA's are set correctly. Cheers, Mike. |
02-21-2010, 11:22 PM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Yup, X2 on what they've all said about end points, when I put the new one in my LCC after getting the DX3e I set teh endpoints so the servo barely moved then adjusted it so the servo stopped as soon as the dig assembly ran out of travel.
02-22-2010, 01:50 AM | #8 |
RCC Addict Join Date: Jun 2009 Location: California
Crack open the manual...or get it offline...It explains everything...I set it up like the manual said and I haven't fried anything yet.. |
02-22-2010, 05:32 PM | #9 |
Ok start low...I started high and worked low until the dig unit was almost touching pushed n and backe it off a hair once fully extended...But I will get another and do it your way!! Haha.... Anyone run the LCC LCG dig servo holder by RCBROS? |
02-22-2010, 06:00 PM | #10 |
Nope, didn't know they were making one, but I don't shop on line either................
02-22-2010, 06:41 PM | #11 |
| There are a few build threads on RCC with some great crawlers using our mount. It truly is a great way to fix the linkage issues associated with the stock location.
02-22-2010, 10:46 PM | #12 |
I use the mount too, just put it in Saturday, no pics yet..... Fits great and makes it simple to mount the servo, now which servo since so many seem down on the Hitec (HS225 at the moment)? |
02-22-2010, 11:09 PM | #13 | |
not a forgiving servo if ya set it up wrong. | |
