Problems!! I just finished putting my LCC together. I am running a novak goat 3s 21.5 with the fan, powered by the losi 3s 1350 mah battery. My run times just plane suck. 5 minutes into the run and the esc starts glitching as well as the dig servo. Does any one have any recommendations for a higher amp battery that will fit the stock tray. |
You did use the bec right? I run almost the exact same setup goat 3s 21.5 tekin brushless & 3s 1350 battery & have no problems at all!! |
better be useing a bec an a 30 c batt if not u will have that |
15 - 20 min |
I asked my lhs owner and he said I shouldn't need the bec but I will give it a shot. But 15-20 is not all that much to look foward too. I get 2 hrs on my creeper with a 2s, but it is a much higher amp battery. |
you need to understand that the losi is a differant truck then the axial or the venom the worm gears need alot of power to turn them & the high torque servos pull alot of amps so yes you need to run the bec & with the losi 15-20 min is good run time if you get anymore good job! Good luck when the truck if setup the way it's suppose to be it works great!! |
Your LHS guys don't know anything then...If I asked my LHS the same question they would say BEC are for Planes and heli...Not cars...You need a BEC. I run a 1350 30c 3S, and can run 4 courses in a comp. |
I had the same problem with my 3s set up. the bec is a 3amp bec. Get a cc bec and you shouldn't have a problem. also what pinion are you running? You may consider putting a fan on your motor also? Heat can cause you problems also! |
You have the goat 3's the BEC that came with it will work fine! thats all I use & as I said I have no problems at all!!"thumbsup" |
Not so., depending on what servo you are running. If you are running a high torque servo, and a digital dig servo(as most are), then you DO need a bec. BUY ONE and you will see the difference, period. And do yourself a favor and find a thread on how to hardwire the bec directly into the servo itself. You will appreciate this word of advice when it's alll said and done, trust me on this. |
I said you need a BEC!!"thumbsup" |
I was havin the same problems but the bec on problems gone ,i also got about 30 minutes runtime today with a 1300 mah 3s,BEC"thumbsup" |
