LCC piston confusion after 2 years with the ax-10 i sold it last week and bought a losi. i had losi shocks on my ax-10. the pistons were pink which is what the #56 is supposed to be, and the cartridge was grey like the shock bodies. well on my new LCC SN#5367 it has black pistons which are supposed to be the #57(which is what i just bought to change to and how i found this out.), and black cartridges. the parts lists says they are #56. but all #56 pistons are pink. what gives:? my LCC also has overly greased packed diffs and V3's CVD. can anyone shed some light on this for me. thanks for replys |
blacks are 57's not 55's. you are the first that i have seen that has recieved the newest revision of the truck everything should be correct out of the box |
every thing wasnt correct i got 2 left instead of a left and right mounts for the dig servo. hopefully they should be here soon. |
Rich stated back when the rig got released that the pistons are molded black in the kit but Are 56's. http://www.rccrawler.com/forum/showp...84&postcount=2 wether that has changed I dont know but he'd be the man to answer that. |
The stock black ones are #56. The colored pistons are made at a different location. You should be able to tell the difference between the two by looking at the edges on the piston. |
yo limpy...what was your serial#? I just got one and it was in the 500's. Thanks. |
Interesting....I did not know that...I thought the black/red were different, even though they are both #56, But its just color....Guess I didn't need to order the reds up. |
I've got a question relating the pistons. How do you know what each piston does differently? How are they different? Fluid holes? Thickness? What? |
Thanks Robbob for the link."thumbsup" |
So what's the rule to consider here, larger piston hole bore. Slower reaction? I know oil wt. has a difference. I just don't want to go shooting in the dark |
Also, the lower the number, the bigger the hole. The lower the number, the heavier the oil to get the same feeling. |
