02-24-2010, 12:37 AM | #1 |
Rock Stacker Join Date: Apr 2009 Location: Brownsburg, Indiana
| LCC piston confusion
after 2 years with the ax-10 i sold it last week and bought a losi. i had losi shocks on my ax-10. the pistons were pink which is what the #56 is supposed to be, and the cartridge was grey like the shock bodies. well on my new LCC SN#5367 it has black pistons which are supposed to be the #57(which is what i just bought to change to and how i found this out.), and black cartridges. the parts lists says they are #56. but all #56 pistons are pink. what gives:? my LCC also has overly greased packed diffs and V3's CVD. can anyone shed some light on this for me. thanks for replys Last edited by limpy88; 02-24-2010 at 01:15 AM. |
02-24-2010, 01:02 AM | #2 |
no talent hack Join Date: Feb 2007 Location: Redwood City
blacks are 57's not 55's. you are the first that i have seen that has recieved the newest revision of the truck everything should be correct out of the box
02-24-2010, 01:15 AM | #3 | |
every thing wasnt correct i got 2 left instead of a left and right mounts for the dig servo. hopefully they should be here soon. | |
02-24-2010, 05:58 AM | #4 |
Rich stated back when the rig got released that the pistons are molded black in the kit but Are 56's. Shock Pistons? wether that has changed I dont know but he'd be the man to answer that. |
02-24-2010, 08:30 AM | #5 | |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
The stock black ones are #56. The colored pistons are made at a different location. You should be able to tell the difference between the two by looking at the edges on the piston. | |
02-24-2010, 09:49 AM | #6 |
Pebble Pounder Join Date: Oct 2006 Location: SOCAL
yo limpy...what was your serial#? I just got one and it was in the 500's. Thanks.
02-24-2010, 10:21 AM | #7 |
RCC Addict Join Date: Jun 2009 Location: California
Interesting....I did not know that...I thought the black/red were different, even though they are both #56, But its just color....Guess I didn't need to order the reds up. |
02-24-2010, 10:49 AM | #8 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
I've got a question relating the pistons. How do you know what each piston does differently? How are they different? Fluid holes? Thickness? What?
02-24-2010, 11:18 AM | #9 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
| The pistons have different size holes in them. #56 pistons have drill size 56 holes in them, #55 pistons have size 55, etc. It is a balancing act trying to get the right weight oil with the correct piston hole size.
02-24-2010, 01:39 PM | #10 |
| I read your post yesterday and meant to tell you the stockers are #56. Sorry. Yup. I just posted the same thing in another thread. I went to the #57 in back keeping the same oil and it makes a drastic difference. Considerably slower, a surprising amount of change really. |
02-24-2010, 02:19 PM | #11 |
Thanks Robbob for the link. |
02-24-2010, 03:23 PM | #12 |
So what's the rule to consider here, larger piston hole bore. Slower reaction? I know oil wt. has a difference. I just don't want to go shooting in the dark
02-24-2010, 05:18 PM | #13 |
02-24-2010, 07:12 PM | #14 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Also, the lower the number, the bigger the hole. The lower the number, the heavier the oil to get the same feeling.
