03-13-2010, 11:41 PM | #1 |
Newbie Join Date: Mar 2010 Location: san diego
| battery run time losi battery
how much run time do you get from the losi 1350mah 11.1 lipo battery in your lcc?
03-14-2010, 08:52 AM | #2 |
Depends on the rest of the set up. Motor used, fan used, high draw servo, pinion gear used?
03-14-2010, 09:55 AM | #3 |
Newbie Join Date: Feb 2009 Location: Sioux Falls
03-14-2010, 02:15 PM | #4 |
Pebble Pounder Join Date: Oct 2006 Location: SOCAL
21.5 ballistic 15t, hitec 333oz, 1350 3s, 35min of run time at about 80% of the pack used. Safe between 30 and 40 min depending on how much throttle you are using.
03-14-2010, 08:22 PM | #5 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
17.5 novak pro. mamba max pro, 8711 servo, BEC, 1300mah 11.1v about 45 min pretty constant. I got alot better battery life on the brushless setup than i did the titan setup.
