03-15-2010, 12:14 PM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: omaha
| Losi worm & pinion gears
I know this has already been asked but looking for any new updates. Has anyone changed from 3 shim's front and back of pinion gear and 1 shim on each side of spool? One of our guys changed the sim count on the pinion gear and drew me to raise this question again. I've gone through 3 sets since last summer and it has not been over used. Also what's your opinion of the best lube for the worm's? This is the last issue that has kept me thinking about switching to Bully's. After MOA, BLC gears, Rhino 1050 mah 40c batteries, and new high clearence chassis, I've been real happy with it. |
03-15-2010, 12:42 PM | #2 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
I have been using a Valvoline synthetic grease with good luck. Brought my worm gear temps down about 10 or 15 degrees. I can now run 15 minutes straight and the axle temps are right around 110 degrees. I have been running 1 shim on each side of the outdrives and the normal 3 on each side of the input, seems to be working pretty well. I have tried to get in the habit of giving the worms a shot of fresh grease once a week, usually the night before my Sunday comps, probably doesn't hurt.
03-15-2010, 02:14 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
I know a lot of people are using Lucas Oil Red and Tacky it is what i use and it works great i can run mine for 30min and the axles are just warm to the touch. and davec is right you have to add grease regularly have you done the grease port mod on the axles? it just makes it easier!
03-15-2010, 07:43 PM | #4 | |
Rock Crawler Join Date: Apr 2009 Location: NorCal
03-15-2010, 08:35 PM | #5 |
Newbie Join Date: Dec 2009 Location: Nebraska
I personally havent had any trouble with mine,but im going to surface harden a set and give them a try.The compound hardens about 3 thousanths deep yet they wont end up being to brittle.That should keep them alive indefinitly.
03-15-2010, 10:22 PM | #6 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Which one (front or back or both) have you had problems with? I did not have any worm problems until the V3's came out. My front worm went about a month after I put the V3's in. I was able to stress the truck without worry of breaking axles, so next in line was the worm I guess.
03-16-2010, 09:32 PM | #7 |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
last week i switched to antiseeze in mine and the back axle was really warm, and the front was cold. but after a while my motor temps were 190 and up i new some thing was wrong. so after i tore the whole truck apart and found out that the imput gear on the front axle was missing half a thread. now i dont know if it was from the antiseeze or a bad bearing, but im not going to chance it again. but my cousin runs the same stuff in his rockforce.
03-17-2010, 05:22 PM | #8 |
i wouldnt use antiseeze for a worm grease as i dont think it would lubricate very well
03-18-2010, 12:37 PM | #9 |
