04-11-2010, 12:52 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
| pull the trigger?
im thinking of buying a lcc and just wanna know everyones opinions looks like most people run the stock chassis is it that good out of the box? i currently have an ax10 with a slingshot and dna dig. no one around here has a losi for me to try or see run will it be worth the swap from the axial? what all will i need to do right out of the box? |
04-11-2010, 01:31 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
The stock chassis is extremely adjustable. It has tons of shock adjustments built into the chassis. Add a delrin skid from sikax10 and its good to go. I also use delrin lower links, too. Slides right over everything.
04-11-2010, 01:39 PM | #3 |
just checked out those skids and links saw he had a 60/40 link set would that be better then stock 50/50
04-11-2010, 01:51 PM | #4 |
I thought about ordering a 60/40 setup, but I already had a set of stock length delin links so I just ordered the skid.
04-11-2010, 03:09 PM | #5 |
im hoping for an upgrade compared to the ax10 does the lcc allow me to raise the "bar" a little more with what i can do with it? also would a vxl hold me over till i get an bl esc for it? or would a holmes hobbies brushed esc and a brushed motor be ok? ive done some searching and seen a lot of bl and some brushed but not a lot of explaining how they do with a brushed system
04-11-2010, 03:25 PM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: UTAH
i had a 7turn puller in mine it did good but go hot, brushed won't last very long, i run a tekin rs now 17.5 with the 14mm torque rotor it does great, i would say go brushless it works a lot better, i had an ax10 before this and my losi is way better for me i have a bully as well and i always come back to play with the losi you will love it.
04-11-2010, 04:31 PM | #7 |
sweet i pulled the trigger amain has them for 264 and got a discount code for $25 off and will get the $50 rebate from losi
