05-28-2010, 10:05 PM | #21 |
Newbie Join Date: Feb 2010 Location: Glendale
wheel weight was going to be my next ? Fronts? rears?
05-28-2010, 10:10 PM | #22 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| It was a couple posts back. Quote:
05-29-2010, 02:03 AM | #23 | |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
After my wheel change I am at 5.46lbs with the Lipo installed. | |
06-01-2010, 09:56 PM | #24 |
| axle steer
Sorry, missed the wheel weights that is total for both front and both rear. Did you test for axle steer yet? I'm collecting all I need to finish my two MOA's before I start building. I have a comp to get ready for this weekend w/my son, have a look at the AZ Summer Shootout on 4th 5th & 6th of June. Team Losi will be there it should be a great opportunity to learn from the best of the local talent and the top pros.
06-02-2010, 06:36 AM | #25 |
Each front wheel and tire = 11.9oz Each rear wheel and tire = 8.1oz *This actually makes my rig 4.44oz lees than before...forgot to double the weight savings! There is some axle steer, but I don't notice it when crawling...only noticed when I tested for it while on the bench. I'm not even sure how it would affect you when crawling...with the front and rear digs and articulation, seems like it wouldn't be a factor? I don't know if a stock one would have any or not. Last edited by mascman; 06-02-2010 at 06:40 AM. |
06-05-2010, 05:06 PM | #26 | |
RCC Addict Join Date: Jan 2010 Location: Lafayette
7t- 2 to 3s (3s may result in overheating). 45a continous 11.1v use, 35a continuous 7.4v use 10t- 2 to 3s.* 40 amps continuous 11.1v use, 30 amps continuous for 7.4v. 14t- 3 to 6s.* 35a continuous 22.2v use, 25a continuous 3s use. HTH Mascman, nice job. Was good to see this thread, it's nearly identical to my parts pile. Looks great. Any issues with clod stall? | |
06-05-2010, 06:12 PM | #27 |
Thanks shelljeep. I haven't really ran it a lot, but the stall doesn't seem bad. I just went to 13 / 12 gearing to see if it will run a tad cooler. |
06-05-2010, 06:16 PM | #28 |
I run my 500 cobalt pullers on 3s with no problems and plenty of wheel speed. I am loving the motors!
06-10-2010, 06:55 PM | #29 | |
My 14t cobalts are 400 size 2s only for them, I'm going to sell both, thanks though. I just got my 27t axials and my BLC regear arrived today. Got to wait now for my son to get back from his vacation we are going to build these two together everything is setting on my bench. I may try bending up the links now and have them ready to bolt in. | |
08-03-2010, 04:07 PM | #30 |
Just some updated pics. I really never decided on a paint or graphics scheme for this, so I just grabbed an old E-maxx body and started cutting. It was free and flashy, so why not?! |
08-06-2010, 02:07 AM | #31 |
Reduce, reuse, recycle. Looks good mang! Did you file the top of your housings flat for the MOA brackets? Started working on mine tonight, looks like they would fit better if you get rid of the hump on top and shorten the 3rd bolt bung. |
08-06-2010, 06:51 AM | #32 | |
Yes, I hit them with the flat side of cut-off wheel...takes care of it in a hurry! Good luck on the build! | |
08-20-2010, 06:52 PM | #33 |
Did you get a final weight RTR?
10-19-2010, 11:20 PM | #34 |
Rock Stacker Join Date: Sep 2010 Location: los angeles
hello just want to know if the where i can order this chassis and beetlejuice v3? thanks |
10-20-2010, 12:50 AM | #35 |
Here's a link to the sales thread in the vendor's market sub-forum, Chassis and Suspension: http://www.rccrawler.com/forum/showthread.php?t=221702 You will not be disappointed, this chassis flat out works. |
10-30-2010, 02:48 PM | #36 |
Pebble Pounder Join Date: Jun 2010 Location: Ontario,Canada
I am wondering if you tried to use the stock LCC Trany in the Beetlejuice V3 lowboy chassis. I want to get the chassis but did not want to go MOA. Thanks for the help
10-30-2010, 05:15 PM | #37 |
Newbie Join Date: Jun 2005 Location: shelbyville
10-31-2010, 01:53 PM | #38 |
Do you think the chassis could be shimmed out enough to make it work with out loosing the advantage of its small size? If not, what other chassis would you suggest.
11-01-2010, 06:36 PM | #39 | |
as far as a diff chassie I cant think of any at the moment. | |
