05-18-2010, 04:51 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Pasadena
| Can you just glue the slipper clutch pads so they wont slip?
hey guys, i just ordered a non slipper clutch gear and a couple other things for my comp crawler, but they are gonna be a few weeks, could i just glue the slipper clutch assembly so its basically just another gear? or will it mess the the truck |
05-18-2010, 04:55 PM | #2 |
Good luck getting the glue to stay on. Try it, won't hurt anything in the truck.
05-18-2010, 05:01 PM | #3 |
ok, i will go for it |
05-18-2010, 05:20 PM | #4 |
Pebble Pounder Join Date: Mar 2008 Location: Marine City
| You can also double nut the slipper, when I got mine it slipped alot also. I got another nut to use as a jam nut and have not had a problem since then with the slipper.
05-18-2010, 07:40 PM | #5 |
mine just strips the actual clutch pads
05-18-2010, 07:57 PM | #6 |
Pebble Pounder Join Date: Oct 2009 Location: in a state of labyrinth
You may try j.b. Weld to see if you can get it to hold. I've seen this done and it will work for a while till the slipper gear gets to you |
05-18-2010, 07:58 PM | #7 |
ok, i will try that, except i dont really know where to get jb weld |
05-18-2010, 08:23 PM | #8 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
Any auto parts store should carry J-B Weld |
05-18-2010, 08:26 PM | #9 |
Pebble Pounder Join Date: Jan 2010 Location: Littleton Crawlerado
your local auto parts or home improvement store.
05-18-2010, 08:39 PM | #10 |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
i CA glued mine and it worked great but every now and then i have to reglue it but it works.
05-18-2010, 11:23 PM | #11 |
Quarry Creeper Join Date: Dec 2009 Location: armpitts, CA
just remove that existing srew/nut thing and replace it with a normal screw and tighten the sh!t out of it. works great on mine, works so good i just strip idler gear with the ballistick motor
05-19-2010, 12:52 AM | #12 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
Why don't you try something simple and removable. Try adding servo tape between the plates. |
05-20-2010, 01:05 PM | #13 |
Newbie Join Date: Jun 2006 Location: OLYMPIA
or for that matter velcro that way if you need to take it apart ....riiiipppppppppppp and its apart.. |
05-20-2010, 01:32 PM | #14 |
i tried a couple things like the servo tape and it just didn't wanna stay stuck. probably the same with velcro, btw i ordered a non slipper clutch gear and it should be here today. but my glue job on my slipper clutch is holding up really well
05-20-2010, 06:24 PM | #15 |
Newbie Join Date: Feb 2010 Location: Glendale
Can someone tell me what the loud hi pitched noise is. I suspect this is why you guys are gluing the slipper or replacing it with a non slipper. Is this the source of the noise? Is there another thread dealing with tranny issues?
05-20-2010, 06:35 PM | #16 |
Newbie Join Date: Apr 2006 Location: Dacula
What about drilling through the the whole assembly and putting a couple of screws in it? Just a thought. |
05-20-2010, 07:32 PM | #17 |
hey guys, just got my non slipper gear, and i gotta say, what a difference, it has a much smoother powerband, and it is about 20 percent quieter, best 14 bucks i ever spent. btw i have a question, my front dig doesn't engage, no matter how hard i push it. but my rear dig engages easily
05-21-2010, 07:21 AM | #18 |
Rock Crawler Join Date: Sep 2009 Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
| That would be some VERY small screws to work.I put my slipper pads next to my grinder and scuffed them a little,then JBwelded them and have had no problems.Might have to try the one piece gear,just to cut down on the noise
05-21-2010, 10:37 PM | #19 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
05-22-2010, 12:01 AM | #20 |
yeah, that seems to be exactly what is happening, thanks so much btw youre the person that got me into crawling, i was that kid at the ama show that was hogging the night crawler. |
