05-23-2010, 05:09 PM | #1 |
Rock Stacker Join Date: Feb 2008 Location: middle of maine
| lcc problems
well i had my lcc out on my rocks in my yard and it did pretty darn well but im haven some problems... i got a brand new 2s goat 18.5 system in my rig and it seems to cog at low speeds sometimes.... also when its running around at full throttle (not on rocks) it makes a clicking noise.. it doesnt do it when im on teh rocks also when my steering gets jammed teh esc cuts out and i have no steering or motor till it comes back on...would a BEC fix that? |
05-23-2010, 05:37 PM | #2 |
a bec would help the cutting out problem as for clicking your dig may be adjusted a bit off mine used to do it till i used the servo trim a bit
05-23-2010, 05:40 PM | #3 |
i havent got my dig set to run yet.. the servo blew and i havent had the funds to replace it... but thats centerd and doesnt bother.. less the tranny is flexing and jammen it in abit
05-23-2010, 06:00 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
Make sure your pinion mesh is right, at low speed it may not do anything until you gas it. Also if your dig servo is still connected but not working it can be off just enough to mess with the dig engagement, it takes very little to make this dig work. And yes a bec is a must have I feel once you throw in alot of torque and another servo.
05-23-2010, 06:38 PM | #5 |
Rock Stacker Join Date: Feb 2010 Location: Muncie, Indiana
make sure your pinion is right and then a bec might help out
05-23-2010, 07:13 PM | #6 |
i got a 12t pinion on it and its set right with a peice of paper.... yeah i guess ill have to get me a bec if i run this rig much more might just shelf it and play with teh 2 ax-10s i have comen my way |
05-23-2010, 10:34 PM | #7 |
Try stretching the dig springs also,(refer to DelMonte's thread.)
