06-03-2010, 05:36 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Pasadena
| Tranny Grinding problem PLEASE HELP
hey guys, i have a losi crawler that is making a weird grinding noise in the tranny. i got it bound up really bad. i cant seem to figure out what it is. i know its not the axles cuz they are super smooth. any input would be great
06-03-2010, 06:55 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
Only way to really know it take it apart and inpect all the parts and put it back together. If it bad there will most likely be parts replacement needed in there somewhere. I just wanted to note that after I reread my post it may have sounded a bit harsh and that was not my intention at all. What I was saying is openig it up is the only way to know for sure. the rest is just assumptions. Last edited by AZrcdriver; 06-03-2010 at 09:53 PM. Reason: added note |
06-03-2010, 07:32 PM | #3 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Spur gear and dig plates are the first things I would check
06-03-2010, 07:33 PM | #4 |
thanks, i figured it out. it was just the molded gears in the tranny had stripped, but know i have another problem, the front dig will go into dig, but it doesn't seem to fully engage....
06-03-2010, 07:55 PM | #5 |
Del monte, i didn't see your message before i posted, i checked both of those things ( i have a brand new spur gear in it and i have metal dig plates) but could you help me with the dig? i cant figure it out. i tried loosening the nut on the dig engagement rod thingy ( the thing that the servo moves) and it didn't work, i have no idea what it could be
06-03-2010, 10:04 PM | #6 |
While I have yet to take apart the tranny as mine has less than an hours use on it by looking at the manual it appears if you assembled it correctly (there doesn't appear to be a snag point here) that if it was not engaging the front dig all the way then you may need to reset your servo setting on your radio after you finished putting it back together.
06-03-2010, 10:56 PM | #7 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
I ran into the same problem w/ my dig when I first set it up and found that I over tightened it. I had to buy the replacement dig package,(couldn't find just the arm to buy,) and replaced the plastic piece that attaches to the dig shaft. Once done however, alot of my problems went away.
06-03-2010, 11:05 PM | #8 |
I'm not sure about the metal dig plates, I have never used them before. Do you have a stock set to throw in and see if it fixes the problem? |
06-04-2010, 01:54 AM | #9 |
If you put too long of a screw through the skid plate into the trans it will stop the dig from working and also grind on the gear.
06-04-2010, 06:38 PM | #10 |
hmmm. i will check the screw thing, del monte, i do not have any stock plates to throw in. it didn't happen before this, i just got didn't use the dig for a while becuase i broke my dig horn, but then i replaced everything and now its not working
