08-06-2010, 02:30 PM | #1 |
Newbie Join Date: Jun 2010 Location: Strongisland
| i have losi nightcrawler, need help?
i am looking for more power in my nightcrawler all around which brushless setup is good and does anyone know of videos on youtube that i can see the setup? for the ones who help thank alot! |
08-06-2010, 03:36 PM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Central NC
I have the Novak Goat 3S 18.5t on my Night Crawler and I'm very happy with it so far. Huge difference over the stock setup. A buddy of mine has the Losi Xcelorin on his LNC and he is happy with it. Although some people have been having some issues with the ESC. |
08-06-2010, 05:54 PM | #3 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Does your buddy have a 21.5 or 17.5 and how do compare it to your system, I've been looking at both setups. Thanks!
08-06-2010, 06:33 PM | #4 |
Rock Crawler Join Date: Jul 2008 Location: Hesperia
I prefer the Xcelorin 21.5, it has great low-end torque, and plenty of wheelspeed--its the perfect balance for my driving style, whereas the 17.5 has way too much wheelspeed for me. which setup you go with depends on your driving style, like Jake does really well with the 17.5 (and the 21.5 for that matter... is there any setup he can't drive well? ), but I feel out of control with it. If you're used to the brushed setup, I would recommend going with the 21.5 to get used to the change in wheelspeed, then decide if you want even more than that and want to move to the 17.5 |
08-06-2010, 07:03 PM | #5 |
So if I start with the 21.5 and want to go to 17:5 later all I have to do is change motor esc will work the same? Yes he can drive can't he! I picked this truck up to see if I would like rock crawling with the thought I would get a high dollar rig if I really liked it, but after watching what the losi team drivers are doing plus alot of other people on here are doing with the losi makes me want to learn to be a better driver and make this rig work like it suppost to! Thanks! Last edited by Vertec; 08-07-2010 at 09:37 AM. |
08-06-2010, 07:13 PM | #6 |
Newbie Join Date: May 2010 Location: Nevada County
Yes, you can always change the motor and keep your ESC. You cant really go wrong with any of the major choices out there. People seem to love the Xcelorin systems, I had a string of bad luck and run a Goat 3s/18.5 Ballistic. My friend i crawl with all the time has a 21.5 Losi and it gets way hotter then mine but i has never failed him. I love the Novak, but people have had bad luck with those too, so.....to each his own. I would stick to the 21.5 if you go Losi, the 18.5 in the Goat would be a good choice, little more wheel speed. Like Del Montess said, the 17 systems are just a little fast, and you have to gear them way down to get the torque and temp you need to keep it in. Look at the Tekin systems to, I run Tekin in my Berg and it's so nice. Good luck, and ANY brushless is WAY better then what you have or any brushed system you can come up with on a Losi, IMO.
08-06-2010, 07:33 PM | #7 | |
I went from a Titan 21t motor w/ 20 pinion to the Goat 18.5 w/ 22 pinion and it has been a HUGE difference. Really amazing the difference in power and wheel speed with the new setup, but low speed control is still very good as well. | |
08-06-2010, 08:06 PM | #8 |
Rock Stacker Join Date: Feb 2010 Location: scottsdale
holly crap those are big pinions. im running a 21.5 ballistic with 13 tooth.. but i have to admit i am lacking in the wheel speed department. ive been waiting for my 18.5 stator to come in and see how that feels. I will prolly go up to a 15 or so till the new stator comes in but 20sumthings good god. How is the low end control with that pinion? woops just realized you guys are talkin about the nightcrawler. diff trans my bad.. |
08-06-2010, 11:16 PM | #9 |
Yea, alot different with the LNC trans vs. LCC trans. Another buddy of mine has a LCC with the Goat 3s 18.5 and he runs a 13 or 14 pinion. Low end control is very good on mine. Can crawl just as slow as the Titan 21t I had on it before. |
08-07-2010, 10:08 AM | #10 |
It seems everytime someone talks about the xcelorin system i always hear the word smooth. Thats something i want to find in a new system, i like to drive slower to see what i can make happen first then speed if that dosen't work, but if poeple are still having some issues with this system and the fact i'm just learning i would not know if it was the system or me if something went wrong.(but that would be with any system i put on until i learn more) I do have a new lcc trans waiting to go in when the time comes, so i would want what motor size thats works best for that trans. sorry! dont mean to steal someones thread i plan on making a build thread soon |
08-07-2010, 01:38 PM | #11 |
i see alot people using the novak setup that why i was tossed up with the losi brushless system.they all except lipos rite prob dumb question
08-07-2010, 04:33 PM | #12 | |
this could also be complicated by the worm gears. they require different driving (kind of) than a ring and pinion, because you have to be more careful in a bind--which is when things start heating up. I had this problem when I switched from my AX-10 to the LCC. I didn't understand when to keep on it to get the rig out of a bind, and when to get the heck off of the throttle so I didn't destroy my motor (which I did a couple times). Its just something that takes time with the rig to learn. Its easier if you have someone to tell you "you're rig is never getting out of that and you're going to blow it up, get off the throttle" (I don't know how many times Jake has said that to me, hahaha), because when you're in a bind, you're first instinct is to power through it, but you have to learn your rig's limits and what it will and will not do, what it can and can't get out of. so whatever motor setup you pick, go easy on it at first, don't try for more than 3 or 4 seconds if you're bound up (then check your motor temp, if it's hot, unplug the battery and give it a few minutes to cool down). you'll learn what you're rig will power through and what it won't, and you'll learn how to drive it to get out of a bind better-- and you won't roast motors like I did, haha. that being said..... i think the 21.5 is best | |
08-09-2010, 03:40 PM | #13 |
Pebble Pounder Join Date: Jul 2010 Location: woodland
I installed a vxl-3s with a 35t motor with a 24t pinion. I know no one would suggest it because of the reverse delay, and no drag brake but you have worms. I have had good luck with it and now i can run 3s lipo if i want.
