09-21-2010, 03:16 AM | #21 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Just make sure everything is tight and the shim is in place between the hex and the bearing. I tighten my wheel nuts every time I swap out my 1300 mah 4s. I've never broken a pin in the year or so I've owned this thing. Hell, I sheared a v3 cvd at the knuckle, right next to the pin hole, and the pin was fine.
09-21-2010, 09:08 AM | #22 |
Just had another thought on the hexes. I wonder how much of the problem can be from the hex not being able to hold itself tight on the pin/axle. Mine have been taken off so many times that I gave up trying to tighten them on and just counted on the wheel holding them on. When my wheels were getting loose I bet that created a lot more slop between the hex and the pin also. |
09-21-2010, 09:18 AM | #23 | |
Quarry Creeper Join Date: Feb 2010 Location: Nevada City, CA
Agreed | |
09-21-2010, 09:37 AM | #24 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
What I've found, with a set of V3 CVD's that I bought, that the pins are .060, but the holes are much larger, .063-.064 which creates slop, so the hex and pin move too much back and forth. Coupled with fact the Losi hex does not have a set screw to hold itself, this will eventually cause the pin to bend(or break) from these shearing forces. I tried to get some proper sized wire, but I had to buy 2000 feet minimum, just can't afford that. Eric D has the better solution, the axle hex pin should be bigger, and tolerances reduced for a tighter fit.
09-21-2010, 03:08 PM | #25 | |
Quarry Creeper Join Date: Jan 2010 Location: Dearborn Hts
That's part of the problem, if I run the shim, the wheel binds when I tighten it. I noticed the bent pins long ago and never paid any attention to them, figuring when they broke, then they were a problem. After seeing the binding and subsequent fried worm I started looking closer at the problem. I've had my crawler since January and the worm was the first thing I broke on it and I believe that was preventable (not counting the dig servo I killed because I was stupid, never leave your receiver powered up and your X-mitter off ), which is what I'm doing now, trying to make it more bullet proof. Over all I'm pretty happy with my LCC, I've seen way more Berg Carnage at our comps than what I've experienced. As far as the AL C's and Knuckles go, I have to find out who made the ones I have. I got them on a Night Crawler I bought for spare parts (and these aluminum pieces). I'm also going to file off the little ridge on the back of the hexes for this weekend, seeing as that's the first place the hexs make contact with the bearings when they bind. Ultimately though I will go to the larger pins I think (you sending those to guys who bought and broke chromo pins Erik?) The axial pins and hexs sound like an option I'm also going to explore, I wonder what Venom Hexs and pins are like, I happen to have a pair of screwed up Venom Axles (bad ring gears) I can rob for parts too. Another thing to tinker with, that's why I love this hobby..... Last edited by sledge57; 09-21-2010 at 03:10 PM. | |
09-21-2010, 05:15 PM | #26 | |
As always and with any/all my products,... if you dont feel like you got your monies worth,.. contact me so we can make things right. | |
09-21-2010, 06:27 PM | #27 |
RCC Addict Join Date: Aug 2007 Location: Seattle
09-21-2010, 06:33 PM | #28 | |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
09-21-2010, 08:38 PM | #29 |
not to hijack but figure Id post what I been running with zero problems. on the front hexes I use the factory ones with stock pins. to help keep the hexes from binding into the bearings I filed the back of the hex down, this leaves a gap if the pins do bend. there is a step on the back side you can see, thats what I filed flat. my pins are bent but even with the nuts cranked I havent pinched the bearings or broken any yet. on the rear I drilled the pin holes out and run these style hexes http://www.integy.com/st_prod.html?p...725&p_catid=16 they use a bigger diameter pin thats captured by the oring. the big benefit is you can get different offsets in .5mm differences, helps changing track widths. I use 3mm in the rear. I found though anything over 4.5mm doosnt allow the nut to fully go on, threads dont go into the plastic lock part enough. 4mm seems to be the same as factory so you could use them on either axle. I also filed down the back of these hexes so I dont pinch bearings also. |
09-21-2010, 09:05 PM | #30 | |
10-12-2010, 02:30 PM | #31 |
Thought I finally broke one of these big hex pins. Come to find out that it was a V3 pin. All hex pins are still in perfect condition. I have to hand it to Losi. The V3 are some great axles. Now to see if I can break a Chromo pin in the axle |
04-13-2011, 08:24 AM | #32 |
Have you had any problems yet with the big hex pins...because i need some new hex's or thinking about just some bigger pins |
04-13-2011, 09:42 AM | #33 |
Nobody has made me aware of any issues to date. This does not mean they are unbreakable though. For the $$$ they are one of the best upgrades you can do. It also fixes the loose wheel problems. I literally take a 1/4 drive ratchet and tighten my wheel nuts. They never come loose when you do that. |
04-13-2011, 10:40 AM | #34 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Haven't put mine in yet.. I'm rocking stock replacements at the moment
04-13-2011, 12:21 PM | #35 | |
So they won't bend or break like stock pins do when you tighten them suckers down. Awesome, i'll be ordering a few things here soon | |
04-13-2011, 09:41 PM | #36 |
| I think that is a sign that its time for anger management. Really though. I would be surprised if even you can break them. I am just a step down from you and I have not had a problem. Even if you magically break them, I think I am selling them for $1 each or less?? Might just want to grab 2 sets since they are so cheap. |
04-14-2011, 09:51 AM | #37 |
| I had "issues" when I ran a 13.5 on 3s but only when my fronts weighed around 1lb each. Even then I ran some packaging plastic behind the hex to take up any slop and I could not have been happier. I could smear a axle pinion at any time but didn't have major pin failures.
