04-19-2011, 12:12 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Nor-Cal; Olivehurst/Yuba City
| RC Bros. High Steer Knuckles or OTA steering?
Which is the best way to go for my LNC sportman rig? High steer knuckles or ota?
04-19-2011, 12:29 PM | #2 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
04-19-2011, 12:39 PM | #3 |
get the 20* C's ........ but then your forced to use the stock knuckles. the C's will pick the steering up and youll notice the improvement in steering and climbing ability. |
04-19-2011, 12:40 PM | #4 |
Rock Stacker Join Date: Jan 2011 Location: Santee CA
I thought I read the knuckles were supposed to be a bit higher, but I just went with those thinking they might be stronger. be prepared to make a steering link prob, I got the stock LCC link hoping it would work but broke a servo horn due to having to file it down on one side for clearance. still trying to get a link to work on this thing...kind of stuck since I dont have access to the tools I need at the time.
04-19-2011, 12:42 PM | #5 | |
dang, day late and a dollar short. really should have looked at that harder before I got these knuckles. Last edited by steeltoe; 04-19-2011 at 12:46 PM. | |
04-19-2011, 01:52 PM | #6 |
Quarry Creeper Join Date: Mar 2010 Location: Central NC
Go with the OTA steering link and get the 20* hubs. You will have to modify the OTA link slightly but its easy to do. I have this setup on my LNC and it works great. RCBROS has some high clearance knuckles and OTA link in the works specifically for the 20* hubs but they aren't available yet. |
04-19-2011, 06:31 PM | #7 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
As mentioned, we are working on a link to accomedate the high steer knuckles and 20* c's. Just to clarify on height, ours are taller then the stock knuckles. With 20*c's and stock knuckles your knuckle rotates backwards and up, giving you clearance similar to our high steer knuckles. However with out knuckles and the 20* c's, you are not even higher. I just wanted to clarify this as it seems there is some confusion. |
04-19-2011, 06:59 PM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
i run 20 cs ota n rcbros lowerd servo mount needed to clearance the link a bit but i like it finally out of the way |
04-20-2011, 12:05 PM | #9 |
thanks everyone for your input. I will got thw 20 route with RcBros stuff...
