06-08-2012, 10:41 PM | #41 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
| Re: Comp Crawler Build
Got the truck back together and took it for a very mild spin around the yard and over some rocks. Axles did great and didn't leak a drop of oil Will try to do better testing tomorrow. |
06-10-2012, 04:43 PM | #42 |
So after testing I saw the oil wasn't thick enough. So I switched to smoke oil treatment with about 40% Lucas oil treatment. Most of you will know it is super thick and sticky and I had to apply it very similar to grease Ran one pack and there was a decrease in heat. Going to run one more pack tonight Seals on the ouputs are still working great! Last edited by TheREDCAT; 10-12-2012 at 09:55 AM. |
06-11-2012, 07:41 PM | #43 |
Good news! Ran the truck today for a couple of minutes to warm up the diffs and then ran for 5 minutes straight with high traction dig turns and kinda fast driving. I touched the outputs and they were only warm, I know there is a small decrease in heat compared to the Red and Tacky. I will let the truck sit tonight and check the oil level tomorrow to see if any is escaping. I still can't see any leaks from the o-rings on the outputs After thoroughly testing this setup I would like to start using other greases and oils |
07-09-2012, 05:09 PM | #44 |
Tested another Lucas grease at the comp in Sioux Falls. It performed well and kept the diffs only warm. Thanks to ghtpdm5 I have some HD moly to try Also when I pulled the axles apart all the oil was still inside and coating the spool. The oil did ok but the heat ended up higher then I wanted. Can't wait to see how cool it runs with the HD moly. Did some tire testing also, I took the homemade dual stage foams that came with the ripsaws and put them in my rovers. Threw them on the front with the new wheels. The foams did very well in the rovers but I do want some C I foams. Need some slightly wider hubs also. Last edited by TheREDCAT; 10-12-2012 at 09:57 AM. |
07-09-2012, 10:12 PM | #45 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
just a word here, i know my diffs were running a bit hot at sioux falls...turns out my mechanic didn't put enough grease in on the rebuild there was just a very thin coating when i cracked them today. that said, the things still aren't wearing. the only place on the gears that shows wear at all are where the pinion exits the housings.
07-09-2012, 10:35 PM | #46 |
Wow still very impressive! Just testing today my diffs got hotter then yours at the comp |
07-09-2012, 11:21 PM | #47 |
was that with the hd moly or the lucas stuff in the pic?
07-10-2012, 08:17 AM | #48 |
Just the lucas. The HD moly will be going in very soon and a Castle BEC should arrive today too |
07-18-2012, 09:15 AM | #49 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
| Re: Comp Crawler Build good to see you are still driving dude......will you be back in Phoenix this fall? I will have my comp crawler back together as well, but probably as a sporty rig.....
07-18-2012, 08:19 PM | #50 |
Thanks I will be back around November 1st. Can't wait to see your rig |
09-17-2012, 12:58 PM | #51 |
Today I finally started to get this truck lighter. Right now I'm working on the chassis. Here are some pics of the first side plate. I forgot to weigh it before but it now weighs only 1.5 oz I am also planning to remove excess wiring and move electronics lower too. Let me know what you think Last edited by TheREDCAT; 09-19-2012 at 06:12 PM. |
09-18-2012, 12:30 PM | #52 |
Got some more work done. Drilled 3 more holes in the first chassis plate and got the other plate done. Here it is on the truck. Lightened the gear cover. Removed little over 1/2 oz of excess wire. Last edited by TheREDCAT; 09-19-2012 at 06:09 PM. |
09-18-2012, 12:47 PM | #53 |
Here it is back together The RX is lowed and the CC BEC is on the battery plate now. Also finally switched over to deans battery connectors. I put the ESC on it's side. Last edited by TheREDCAT; 09-19-2012 at 06:08 PM. |
10-12-2012, 10:42 AM | #54 |
Lost some weight from the transmission. Sipped the rovers. It's working great Last edited by TheREDCAT; 10-12-2012 at 10:48 AM. |
10-12-2012, 02:34 PM | #55 |
Quarry Creeper Join Date: Mar 2009 Location: Phoenix
very nice build up RedCat! I have an lnc with a bunch of little mods performed on the way to where it is today. love the performance as well as being super impressed! I am contimplating either rovers or sedonas for my tire upgrade as my stock losi claws are rolling to much on themselves also and binding up the truck. funny to watch but a pain to wheel! Post up when your back in phoenix, perhaps a few of us can get out for a crawl somewhere. Ryan |
10-12-2012, 08:39 PM | #56 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
I've actually been wanting to run oil in my axles. I have a box of o-rings and your idea sounded like it worked. Do you happen to have a picture of how you set it up?
10-12-2012, 09:06 PM | #57 | |
| Re: Comp Crawler Build Quote:
10-12-2012, 09:45 PM | #58 | |
At the top of this pic you can see the o-ring I used. When I used thinner oil I used grease trying to seal all the moving parts and Blue RTV sealant around the case. Here you can see the Blue RTV and the thinner oil. When I switched to the smoke oil treatment instead of Blue RTV I just used grease around the case and all moving areas. Also I didn't fill the axle tubes with grease since the oil treatment is thicker it stayed inside better requiring less prevention. The o-ring just slipped over the output shafts and fit snug on the shafts to seal them. Then the drive shafts held them on and when installing them I put the setscrews as far out on the shafts to not put a lot of pressure on the o-ring. The o-rings wore in a groove on the axle case after a while, didn't seem to hurt anything though. Made sure to keep the o-ring lubricated also. | |
10-13-2012, 10:29 AM | #59 |
I must be retarded. I can't fig out where the o-ring went. It went over that blue bearing?
10-13-2012, 07:20 PM | #60 |
When the axle is assembled you slip the o-ring over the diff outputs before you install the drive shafts from the transmission. Hope this helps |
