02-12-2012, 09:09 PM | #1 |
Newbie Join Date: Feb 2012 Location: Sheridan
| braking axles
is their a better front axle shafts for the LCC ? I broke both fronts in matter of minutes I stole the ones from my LNC so im still able to play around in the yard
02-12-2012, 09:15 PM | #2 |
| Re: braking axles
are they the axle shafts with the retainer spring to hold in the pin? if not get them and you'll never have to worry about them again! I broke v1, and v2 shafts. now I have been running the v3 shafts (Losi brand) that have the retining spring and nevr had a problem! these- http://www.rpphobby.com/product_p/losa3196.htm Last edited by 2500hdon37s; 02-12-2012 at 09:20 PM. |
02-12-2012, 09:16 PM | #3 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
| Re: braking axles
you probably had an earlier version axle, did the broken one had a ring around the cvd cup like the lnc ones? if not its an earlier pos, if so, then you've done something pretty impressive. the v3 cvd's are pretty stout. and no widely available replacement at this time.
02-12-2012, 09:46 PM | #4 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
| Re: braking axles
The ones you got out of the LNC are the ones you want in the LCC. Does anybody know if Losi updated the newer LCC with the HD cvd's (V3's)? |
02-12-2012, 10:02 PM | #5 |
Pebble Pounder Join Date: Oct 2011 Location: loveland
| Re: braking axles
i know mine was a later LCC and it did come with the V3s im pretty sure. I have only broken one pin and that has been since those shafts have been in my axial.. but its a different story there. My roommate has a later one too and it also has yet to have a problem and his is later serial # than mine
02-13-2012, 09:10 AM | #6 |
| Re: braking axles |
02-13-2012, 02:46 PM | #7 |
Thanks for the info on the newer LCC's cvd type. Sent from my Desire HD using Tapatalk |
02-13-2012, 07:57 PM | #8 |
| Re: braking axles
Glad to here that my LNC axles are better than the older LCC so now just need to buy a set to replace the LNC axles. I would post pic but cant figure how to yet, LOL
02-14-2012, 09:37 AM | #9 |
| Re: braking axles |
braking axles - Similar Threads | ||||
motor braking? | josh6575 | Newbie General | 4 | 05-15-2011 03:27 PM |
braking chasis | slowride1 | EnRoute Berg | 36 | 03-01-2011 06:06 PM |
xl-5 braking question | stoneface | Electronics | 8 | 08-24-2010 07:59 PM |
Roster Braking | Shoei1 | Electronics | 4 | 09-14-2007 12:13 PM |
Braking Question | Fishmaxx | Electronics | 6 | 01-27-2005 06:18 PM |
