05-31-2012, 10:47 PM | #21 |
Rock Stacker Join Date: Feb 2011 Location: riverside
| Re: Tekin redline in a lcc
it was pretty sick! aha but im trying to get a brushless setup and hopefully that will solve my problem! if you ever need help disassembling your whole truck twice in 2 days then im your man! ahah at least you get money to buy crap for it! and i was told to run these batteries Sky Lipo 1000mAh 11.1V 40C |
05-31-2012, 10:53 PM | #22 |
Newbie Join Date: May 2012 Location: SoCal
Well those batteries seem promising and cheap...yay! Cheaper is always good |
05-31-2012, 11:07 PM | #23 | |
| Re: Tekin redline in a lcc Quote:
I've been considering 4s Just imagine the axle carnage | |
05-31-2012, 11:25 PM | #24 |
the guy i was talking with had two and his brother had like ten! ahaha i already have 1 2 cell lipo but i need a charger before it does anything! aha |
05-31-2012, 11:40 PM | #25 |
To losikid you are insane... But it would be pretty interesting to watch I'm not gonna lie To Aaron 10 batteries that's slightly overkill haha |
06-01-2012, 01:05 AM | #26 | |
I've got the axle situation figured out, i've been working on something, but i don't want to buy new batteries, sacrifice my cog, and risk destroying my rs because of the 4s... | |
06-01-2012, 02:06 AM | #27 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: Tekin redline in a lcc Smart man. But why are you using the pro? Did you just have it laying around? I have an rs in a box but sure if I want to put it in my lcc or in my mod t4. The t4 has been hanging on the wall wanting to be driven for a few months.... |
06-01-2012, 04:37 AM | #28 |
Rock Crawler Join Date: Nov 2009 Location: poteau
check out corky's videos in the video section ARCC comps. he runs his losi on 4s. works really well! HD spool and worm in front, dlux chromo in rear. i just swapped my motor out yesterday from an 18.5t novak ballistic crawler to a 13.5t. it makes a huge difference. on the 18.5t i was running a 14t pinion, on the 13.5 i dropped to a 12t pinion. the speed of the 13.5 is quite a bit more. i run the sky lipo batteries, mine are 800mah 3s 40c's and they last around 10 minutes. i can tell the 13.5t will drain the battery quicker so i gotta do some testing and see how long they will last now! |
06-01-2012, 08:00 AM | #29 |
Hey hoghead5150 if you try that let us know how it goes I still have time to contemplate motors....
06-01-2012, 04:29 PM | #30 | |
06-01-2012, 04:42 PM | #31 |
i'll keep an eye on them thanks. i've only ran 2 packs thru it so far (raining now), and i got between 8 to 10 minutes out of each pack. this was just normal backyard driving, LOTS of full throttle running, and some mild crawling. will have to head up to the waterfall and put it thru some comp style crawling with quite a few binds to check how everything reacts to the new motor.
Tags |
17.5, castle creations, lcc, redline, tekin |
Tekin redline in a lcc - Similar Threads | ||||
Waterproofing A Tekin Redline | sixhundred71 | Electronics | 2 | 06-01-2012 06:43 PM |
