| | #21 |
| No kill like Overkill ![]() Join Date: Nov 2009 Location: wells, mn
| just solder the leads on to the mains wires for the esc when you're putting it together |
| Sponsored Links | |
| | #22 |
| Newbie Join Date: Apr 2011 Location: Streetsboro
| Thanks for the heads up. I've let plenty of magic smoke out in other e- projects! |
| | #23 |
| aye, same here. pretty much all the rc electronics have a voltage rating if you dig in to spec for them. with the high torque amp hungry servos used for steering, you really have to balance things out. the ccbec can handle them great, but internals are usually poor to "who thought this would work?". also keep in mind that due to the natural of the worm drives, you're going to be facing a higher amp draw from the motor as well. the inherent friction is just the main factor there. make your battery choice wisely. |
| | #24 |
| I'm guessing with the battery the higher the "c" rating the better or are we talking brands as well (we get what you pay for type of thing)? |
| | #25 |
| Rock Crawler Join Date: Dec 2011 Location: Australia Queensland!
| Most lipos are good I mean you look at hobby king turnigy and zippy lipos they are cheap and work very well. |
| | #26 |
| The 'c' is the current. Most lipos are always at least 20c which is alright but anything higher is better. It doesn't matter so much to some but with crawlers and RC's in general a higher current/burst current is always better but you pay more for it. |
| | #27 |
| RCC Addict ![]() Join Date: Jun 2005 Location: St. Albans, WV
| 30-35C minimum for most brands of packs. Most 20C packs do not like the losi. The CBP 25C 850mah seem to handle it well. Their 35C 1000mah packs are even better, but a little larger. I've killed many of the inexpensive hobbypartz packs using them in my losi... |
| | #28 |
| Quarry Creeper Join Date: Oct 2011 Location: Great Outdoors
| C rating means very little by itself. C x MAH equals the max current the battery should deliver, so a big battery doesn't need a big C to push a Losi motor. Small batteries need bigger C's. A 20C pack with 1000 mah in theory will perform the same as a 40C, 500 mah battery. And while it's heavier, it will also last longer. Pick what's important to you. Last edited by Hardline; 01-04-2013 at 09:28 PM. |
| | #29 |
| have to factor in c pumping in advertising too here. its not an honest way to do business, but a lot do it. cbp.com has posted publicly on this forum tests on their elite series packs. i run their 1000 mah 3s's for practice packs, and smc 45c 850 skinnies for actual runs, both have about the same snap off the line, but for the money, cbp.com has my vote. those packs are still just as hard hitting as they were the first time i powered up my truck. |
| | #30 |
| Quarry Creeper Join Date: Dec 2011 Location: magalia
| You should try and post some better pics of how you did your chassis. I'm a little curious as to how you did it |
| | #31 | |
| Rock Stacker Join Date: Oct 2012 Location: Harleysville
| | #32 |
| | #33 |
| I went through one chassis plate trying to just center my trans lol but thanks bud. I was wondering how you did it |
| | #34 |
Starting to mod my LNC - Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| starting to mod my wk again | iceman320 | HPI Wheely King | 11 | 12-25-2007 09:50 PM |
| Starting to mod my crawler | Going Up! | General Crawlers | 21 | 01-02-2007 09:17 PM |
| Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
| mine, starting to mod | Sarge | General Crawlers | 9 | 01-04-2006 09:57 PM |
| Thread Tools | |
| Display Modes | |
