03-27-2014, 08:52 AM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: morristown
| brushless sistem
I have a lcc my novax goat 3s just craped out on me. I was running there 18.5 motor with 12t also. what is a good system to get. that will get me close to what I was running.
03-27-2014, 11:11 AM | #2 |
Pebble Pounder Join Date: Oct 2012 Location: Plattsmouth
| Re: brushless sistem
Tekin RS system or either Tekin RS and a Tekin ROC motor or Castle MMP and tekin motor or Holmes motor! IMO!!
03-27-2014, 01:03 PM | #3 |
ok so I am going to get a mmp what turn motor should I get will be running on 2s also
03-27-2014, 04:40 PM | #4 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I would keep the 18.5 and 12T pinion Go to a MMP and run 3 or 4S |
03-27-2014, 04:51 PM | #5 |
Your 18.5 should be fine on. 2s but might need to try a few pinions to get it where you like it! Or you could run 3s like GiJoe said!
03-27-2014, 07:10 PM | #6 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
4s 13.5t . But 13.5T on 2s goes good.
03-27-2014, 07:45 PM | #7 |
Ok just ordered the mmp and a 3s
03-27-2014, 11:31 PM | #8 |
Quarry Creeper Join Date: Dec 2013 Location: San Diego county
I'm 18.5 and 3s on mmp and a 20t pinion, works good
03-28-2014, 07:09 AM | #9 |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
| Re: brushless sistem In an Night Crawler, totally agree. In an LCC, 15T pinion max. Of course, depending on driveline efficiency. Speaking from not having tried a 13.5T, I think it's better to have a higher turn motor with more juice (3s-4s). It IS a larger battery you have to deal with, but it works out to be more RPMs while retaining the torque of the higher turn motor, longer runtimes, cooler electronics, and on and on. The MMP is a great ESC that allows amazing adjustability, as well as being stout enough to be able to experiment with battery size (3s, 4s - IMO 5 and 6s will just be insanity). |
03-28-2014, 09:37 AM | #10 |
Sounds like its time for a lnc tranny and a flip! I completely agree with the higher turn motor, I'm getting about 20-25min runtime on a 850 mah
03-31-2014, 11:42 AM | #11 |
Ok got the mmp today I have never set one up I got the link for it also what do most of you set it at
03-31-2014, 12:32 PM | #12 |
Il check my settings later when I get home Sent from my Lumia Icon using Tapatalk |
04-05-2014, 08:23 PM | #13 |
Did you ever get to check your settings
