brushless sistem I have a lcc my novax goat 3s just craped out on me. I was running there 18.5 motor with 12t also. what is a good system to get. that will get me close to what I was running. |
Re: brushless sistem Tekin RS system or either Tekin RS and a Tekin ROC motor or Castle MMP and tekin motor or Holmes motor! IMO!! |
Re: brushless sistem ok so I am going to get a mmp what turn motor should I get will be running on 2s also |
Re: brushless sistem I would keep the 18.5 and 12T pinion Go to a MMP and run 3 or 4S |
Re: brushless sistem Your 18.5 should be fine on. 2s but might need to try a few pinions to get it where you like it! Or you could run 3s like GiJoe said! |
Re: brushless sistem 4s 13.5t :twisted:. But 13.5T on 2s goes good. |
Re: brushless sistem Ok just ordered the mmp and a 3s |
I'm 18.5 and 3s on mmp and a 20t pinion, works good |
Re: brushless sistem Quote:
Speaking from not having tried a 13.5T, I think it's better to have a higher turn motor with more juice (3s-4s). It IS a larger battery you have to deal with, but it works out to be more RPMs while retaining the torque of the higher turn motor, longer runtimes, cooler electronics, and on and on. The MMP is a great ESC that allows amazing adjustability, as well as being stout enough to be able to experiment with battery size (3s, 4s - IMO 5 and 6s will just be insanity). |
Sounds like its time for a lnc tranny and a flip! I completely agree with the higher turn motor, I'm getting about 20-25min runtime on a 850 mah |
Re: brushless sistem Ok got the mmp today I have never set one up I got the link for it also what do most of you set it at |
Il check my settings later when I get home Sent from my Lumia Icon using Tapatalk |
Re: brushless sistem Did you ever get to check your settings |
