YB's outrunner sportster Still collecting parts at this point, but after seeing a few people go trannyless with the losi axles I have to try it for myself. Here is the heart of the project, turnigy outrunner motor will be chassis mounted and direct drive to the losi axles w/ wildboar driveshafts. http://i665.photobucket.com/albums/v...pslzd1hnhx.jpg Here's my solution for XR outers on a losi axle. I cut the ends off of an Axial AR60 axle and drilled them to fit over the losi axle tubes. (15/32 drill bit is a perfect snug fit.) It's important to not drill too deep, so you leave enough "meat" in the axial plastic where the splines begin. http://i665.photobucket.com/albums/v...pski4lfgwy.jpg |
Re: YB's outrunner sportster Made this little fixture for welding the losi/axial shafts together. First I drilled a hole the diameter of the axial shaft, then I drilled that same hole the diameter of the losi shaft to half depth. Then I cut right down the center line of the hole. This ensures that the two shafts are perfectly centered on each other before welding. http://i665.photobucket.com/albums/v...psmkmpximj.jpg Used vice grips to hold everything tight while welding. http://i665.photobucket.com/albums/v...pse5d7k4d4.jpg Shafts welded and cleaned up ready to be installed. The bearing for the axial shaft must be installed before welding because it won't fit over the losi shaft. http://i665.photobucket.com/albums/v...psqflnk0id.jpg |
Re: YB's outrunner sportster Quote:
Are you sure the bearings are needed,-the TAG-kit do not use them,-or maybe the extra support is useful with the plastic tubes.... ??? :) |
Re: YB's outrunner sportster Here is an interesting thread on german. May you understand it a bit"thumbsup" I like the sensor-mod. Sportsman Innovation: Sportsman by ed.el. - 2,2" Losi - rockcrawler.de |
Re: YB's outrunner sportster Wheels & tires: silver Voodoos - narrowed, reduced, clipped, and vented (thanks Purptr8r! "thumbsup") CI foams, 2.2 buggy rims w/ .725 SLW hubs. Track width of the front axle is 11.25" with this setup. http://i665.photobucket.com/albums/v...psugi9xook.jpg http://i665.photobucket.com/albums/v...psscb7cwll.jpg |
Re: YB's outrunner sportster Nice front axle"thumbsup" Great job"thumbsup""thumbsup" What is the colour of the knuckles? Never seen them before... Here are the sensors: Hall Effect Sensor Board | Equals Zero Designs Are you planning on running a stock Losi axle in the rear or will you do the XR mod there too? |
Re: YB's outrunner sportster The knuckles are Vanquish and I'm not sure who made the Chubs, maybe hot racing. Thanks for the sensor link!!! "thumbsup" "thumbsup" Thats cool stuff. I hope to use a micro sidewinder for small size and weight but if the outrunner cogs badly I will definitely be trying that sensor setup. I'm going to run a stock rear losi axle. Some of you run stock 25t gears in the rear and HD 21t gears in the front for overdrive, right? Hows that working out? |
Re: YB's outrunner sportster Cool stuff Brian, going to come to a comp? :mrgreen: |
Re: YB's outrunner sportster Made a servo mount/electrics plate/truss all-in-one. I shaved the shock tabs down to make room for the ESC on one side and the BEC on the other. All electrics except for the motor will be on the front axle. http://i665.photobucket.com/albums/v...psfpvkfcwd.jpg |
Re: YB's outrunner sportster Which ESC are you going to use? |
Re: YB's outrunner sportster For ESC I'm going to use a Castle micro sidewinder. It fits under the 7950 servo, and the BEC will fit under the battery. Trying to fit the tie rod above the link mounts but below the pinion is proving to be tough but I think it will work. http://i665.photobucket.com/albums/v...pss38qhjjl.jpg |
Re: YB's outrunner sportster Made the chassis and motor mount plate. Still need a few holes and braces. Just barely wide enough for the out runner motor. http://i665.photobucket.com/albums/v...psjguhbxdt.jpg |
Very nice !! "thumbsup" |
Re: YB's outrunner sportster |
Re: YB's outrunner sportster Awesome Man:thumbup::thumbup: |
