11-29-2014, 10:21 AM | #1 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| So 5 years later what are you running?
Been watching a couple of build threads and made me curious as to what people are running now that the losi is an old goat. The LCC was my first crawler and I will run it until I can't get parts anymore Things to post: Do you comp or not Chassis Motor/pinion ESC (setting if you want) Battery Mine are- Comp-YES!!! Custom Ringer II Original Tekin Redline 21.5t w/ 14mm HT rotor 12t pinion Decased MMP Minimum 10% throttle input, Cheat mode-30* advance at 16500-19100 rpm Nanotech 4s 850mah Last edited by mrG; 11-29-2014 at 05:40 PM. |
11-29-2014, 10:35 AM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Kronach, Bavaria, Germany
| Re: So 5 years later what are you running?
My shafty: -Comp: yes -CCC Boxer 2.2S -Novak Ballistic 18.5T/ 18T pinion+JENS mod -CC Mamba max pro 1S -Rockamp 3S 600mAh Sent from my Sony XPeria Z using Tapatalk |
11-29-2014, 11:49 AM | #3 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
comp: yes. chassis is a custom job by alexg that took some height out of the original phoenix. raise link packages on each end (rear stock phoenix, 1in rise over stock, front hand made by me deal that i'll get into a more polished version one of these days) losi scb shocks, trinity x-ring seals, rpm 2 stage pistons, 25wt oil (i think) on all 4 corners. full fmj throughout the truck in all losi plastics and some delrin parts. ti lowers, 6061 aluminum uppers, all powdercoated by my local sponsor clapped out mmp that i've removed and resoldered a ton of stuff on to save some weight backing up a tekin 17.5t that really needs a bearing change. hs-225mg dig, 7950 steering (direct battery bypass ccbec powered at 7.4v). both have aluminum arms and a home brew but very effective dig servo linkage fix. steering parts are 1/8 steel rod. xr-mod front axle. vanquish wraith parts, rcbros arms, d-lux no slops, way too much loctite involved on the kingpin bolts. lightweight trans internals, dig spring fixes, lightened all the plastic gears with a drill. stampede driveshafts (butter smooth cheap goodness) 21:1 fronts, 25:1 rears, worms are riding in hpi bronze bushings. fast eddy bearings on everything that takes them. TAG carbon wheels with panther leopards and ci foams. 600 vp hubs in the front, 225 flipped in the rear. as much aluminum hardware as i can get away with. about 3lbs 13-14oz rtr depending on the battery. bushings: front axle: dig servo linkage fix: upskirt: and just looking good in the driveway: |
11-30-2014, 07:34 AM | #4 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I have MANY Losi based scalers in various classes that I comp with! All my rigs are built around the SORRCA Scale Rules for Class 1, 2 and 3 #1. "AZAZEL 1" (Replica of my personal 1:1 rig) Comp: Yes Class: 2 and 3 (possibly Class 1 next year with a few changes) Motor/Pinion: Novak 13.5 / 16T ESC: Novak Goat 3S Battery: Turnigy 2200 3S Other: SCX-10 Chassis, HD Worms, HR Metal Gears, 4 Wheel Steer (Class 3 only), Full Interior, Winch Tires: Pitbull XOR (class 3), Cut Boggers (Class 2) #2 "Corrosion of Conformity" Comp: Yes Class: 3 Motor/Pinion: Novak 18.5 / 12T ESC: MMP Battery: Turnigy 1600 4S Tires: Pitbull XOR (Single wheel), Pitbull RBII Front, RC4WD Cut Boggers (Duallies) Other: L-Trail Chassis, Custom 4-Cantilever/2-Shock Suspension, DIG, HD Worms, Metal Gear trans, F/R Winches, Full Interior #3 "Red Truck" (Replica of my buddies 1:1) Comp: Yes Class: 2 Motor/Pinion: Novak 17.5 / 15T ESC: MMP Battery: 2-Turnigy 2200 3S "Saddle Pack" in series to 6S Tires: Cut Boggers on Bartos Wheels Other: L-Trail Chassis, HD Worms, HR Metal Trans Gears, Winch, Full Interior Ive also got a few more projects in the works! I'll post those later! |
12-02-2014, 03:46 PM | #5 |
Here somepics of mine: Sent from my Sony XPeria Z using Tapatalk |
12-02-2014, 04:53 PM | #6 |
| Re: So 5 years later what are you running? Do you comp or not - not anymore Chassis - stock LCC with CF shock tower arms and delrin skid Motor/pinion - no/no ESC - Castle MMP 1C Battery - Hyperion 1100 I finally hit 88 mph with it, and it reverted back to having the battery and receiver and ESC trays in place. Old Comp Claws too. |
12-03-2014, 06:26 AM | #7 |
Pebble Pounder Join Date: Jun 2012 Location: upstate,ny
No comps, Novak esc & 21.5 motor pretty much box stock except weighted wheels. Run it once in a while.
12-03-2014, 07:14 AM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
Eeepee get that thing back in use. remember the fun times you two had together
12-03-2014, 07:18 AM | #9 |
comp yes scale and still fighten a losing battle, still comping 2.2 pro with mine. still keeping up with it. wins every now and then not as much as it use to damn moa's
12-03-2014, 09:18 AM | #10 |
Rock Stacker Join Date: May 2014 Location: Germany
Hey, here my losi shafty: -tekin redline 21,5T motor -mamba max pro -hitec 7950TH servo -sls lipo 1000mah + 1250mah -rockstar custom chassis -XR-Mod on the front axle -tires: rover white (narrow by braune) -comps: yes Weiße's XR-Losi Shafty Last edited by Weiße; 12-03-2014 at 09:25 AM. |
12-03-2014, 10:17 AM | #11 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
| Re: So 5 years later what are you running? |
12-04-2014, 11:19 PM | #12 |
So 5 years later what are you running? - Similar Threads | ||||
Ya'll running 35T motors, what pinion are you running? | concretejungle | Axial XR10 | 9 | 03-11-2012 08:18 PM |
10 years | Eritex Inc. | Chit Chat | 24 | 07-22-2010 10:52 PM |
9-11-06 5 years later | dezfan | Chit Chat | 5 | 09-11-2006 01:30 PM |
