Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Night Crawler links
Old 12-19-2014, 10:29 AM   #1
Default Night Crawler links
Hi All-
Just put HB Rovers on the LNC. Looking to make custom bent lower links now.
I'm looking to save a little time-Question is which screws do I need to remove to pull the lower links? I can dig around and figure it out, but if someone can let me know that has removed them before I'm sure I can save the time of removing thing I probably didn't have to!
Thanks!
Yamaguy is offline   Reply With Quote
Old 12-19-2014, 01:42 PM   #2
Default Re: Night Crawler links
For the lower links, you have 2 screws on the plastic center frame and 2 on the axle...
SilmarilS is offline   Reply With Quote
Old 12-20-2014, 09:48 AM   #3
Roger that. For the center frame screws- if I remove them an them alone will the links come off the frame?
Or is there more neccesary disassembly?
Thanks!
Old 12-20-2014, 10:21 AM   #4
yes they will come off the frame....
You only have to undo 2 screws per links... nothing more...
Old 12-20-2014, 01:19 PM   #5
Very good. Thank you
Old 12-20-2014, 07:06 PM   #6
Correct, but doesn't say it all. Unlike most link attachements, the Losi lower links fit on a pin held by a couple of brackets and the two noted screws. So yeah, it comes apart easy. But that's a lot of little pieces to reassemble in a crowded area, especially if you tried to save time and didn't disassemble anything else. You've been warned.
Hardline is offline   Reply With Quote
Old 12-20-2014, 09:30 PM   #7
You only have the slide pin and the two plastic parts that held the pin.... It's not like rebuilding a complete tranny!
Old 12-20-2014, 10:29 PM   #8
Actually, rebuilding the LNC tranny is remarkably easy. But you're right, so is installing the links if you can reach everything easily. On a fully assembled car, I found it to be frustrating. But doable.
Old 12-21-2014, 08:13 AM   #9
That was my concern. It's not brain surgery and I can see from the diagrams what stuff holds the links... But with grown up sausage fingers am I settin myself up for massive frustration by leaving everything assembled and trying to just work the links?
Looks like getting the pin holders back in and lined up might be a nightmare.
Suggestions?
Old 12-21-2014, 08:31 AM   #10
WAM
The upper links attach easily. If you have trouble getting your fingers in to install the lowers, maybe temporarily remove the uppers to get more access. Also the outer end of the lowers install easily, so do that end last. But it's nothing you should be concerned about. Just part of learning the car.
WAM is offline   Reply With Quote
Old 12-21-2014, 11:53 AM   #11
Getting the uppers out of the way - good idea.
Thanks for the help!
Maybe I'll just build some upper links while I'm at it then!
Great forum! Thanks for all the help and Merry Christmas
Night Crawler links - Similar Threads
Difference in AX10, Night Crawler, and Comp Crawler final gear ratios? shelljeep Newbie General 11 02-05-2010 12:48 AM
comp crawler with night crawler links klaygrover Team Losi Comp Crawler 5 01-13-2010 08:16 PM
