12-21-2014, 07:14 PM | #1 |
Newbie Join Date: Nov 2014 Location: Jacksonville
| LNC upper links
If I make custom bent lower links- mild bend 30 de got so... It seems they will rub the upper links at flex. Should I also make uppers with just a little bend to offer more clearance or will that just leave the driveshafts too vulnerable? I want the additional ground clearance of the bent lowers- but want to keep the deep articulation. Thoughts? |
12-21-2014, 11:48 PM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: LNC upper links
You can have a little bend and not affect too much the flex... Sure, you will loose a little flex, but not enough to change the capability of the crawler.
LNC upper links - Similar Threads | ||||
upper links | WICKEDWOLFRC | Axial XR10 | 3 | 10-04-2011 09:02 PM |
Upper links and lower front links | TrademarkJeff | 2.2 Scale Rigs | 1 | 03-30-2010 11:03 AM |
