05-24-2015, 09:21 PM | #1 |
Newbie Join Date: May 2015 Location: Utah
| LNC Run Time
I'm thinking of getting a Night Crawler as my first crawler. I've read that the worm drive kills the battery/run time. I know a lot depends on how and where you're driving, but I'm just curious what kind of run times you get and with what battery? Thanks.
05-24-2015, 09:26 PM | #2 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
| Re: LNC Run Time
I use Turnigy 5000Mah 2 cell 25c liposon the SCX10 about 20 to 40 mins run time easy.
05-24-2015, 09:34 PM | #3 |
| Re: LNC Run Time
A SCX has absolutely zero to do with the Losi. Literally, none. Nothing. 1100 mah packs will get you about 15 minutes. Nevermind that a 5000 mah battery should be lasting you driving a SCX all day… |
05-24-2015, 10:01 PM | #4 |
| Re: LNC Run Time |
05-24-2015, 10:31 PM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: LNC Run Time You question makes me wonder why you want a LNC? What do you plan to do with it? It's an excellent technical crawler. But at endurance or speed it sucks. Not a natural trail machine.
05-24-2015, 10:43 PM | #6 |
| Re: LNC Run Time Want it as a crawler. I already have a Traxxas for speed/trails. Just curious to know if I'm going to need a pile of batteries and/or recharge every 15 mins. Or do people get longer run times than that?
05-25-2015, 12:58 AM | #7 |
Quarry Creeper Join Date: Jul 2013 Location: Kronach, Bavaria, Germany
| Re: LNC Run Time
I'm running a 430mah 4S lipo on my comp rig and it lasts more than 25mins Sent from my Sony XPeria Z using Tapatalk |
05-25-2015, 05:31 AM | #8 |
| Re: LNC Run Time
I also get bored or some part broken before running out of battery power. To get the most out of your battery read the friction thread. (See signature for details about my crawler.) |
05-25-2015, 09:30 PM | #9 |
| Re: LNC Run Time
Thanks for all the replies. Do the worm drives really suck that much power? How do these run times compare to say an Axial SCX10 or AX10?
05-26-2015, 01:29 AM | #10 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: LNC Run Time
I run a brushless setup on my LNC, and my old 1500 2S pack delivered 45min of rock time. I now have 1000 and 850 3S, not tried it on the rocks yet, But should be ±20min each. |
05-26-2015, 03:17 AM | #11 | ||
| Re: LNC Run Time Quote:
Crawlers with regular gears sporting the same battery and motor and driven the same way (route and wheel speed) should have almost twice the runtime. (Read more about it in my worm drive thread.) Quote:
Only when you make use of the extra power available will the new battery drain faster. | ||
05-26-2015, 06:13 AM | #12 | |
Rock Stacker Join Date: Oct 2011 Location: Sydney, Australia
25 mins seems the average. | |
05-26-2015, 06:45 AM | #13 |
| Re: LNC Run Time
Thanks again. I really appreciate the replies. I'd feel pretty good if I could get 20-25 mins out of them. I just want to be able to stay and play and crawl for as long as possible and for as long as it takes for my boy to burn thru his batteries for his Traxxas.
05-26-2015, 02:22 PM | #14 |
| Re: LNC Run Time
If you plan to run longish times be sure to keep track of the temperatures of the various pieces. The worms, servo, motor and esc can all get hot. Also note that the worms require regular re-greasing. Many of us use one or two threaded & plugged ports on each axle to shoot in grease between maintenance.
05-26-2015, 02:54 PM | #15 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
| Re: LNC Run Time
I ran a G6 with my Losi converted to a Class 2 Scale crawler. 98 gates and over a mile long trail. Did this with (2) 2200mah 3S batteries tied in series for 6S. Basically a saddle pack.... I the course took me about 45min to complete. I did not have to change batteries. My combo that day was HD Worm Gears, Novak 17.5 Sensored motor, Mamba Max Pro ESC, Castle 10amp UBEC 15T Pinion and 4.75" dia tires. The Losi can be a capable trail rig! There is just a few things that MUST happen to get it there. I've been competing in SORRCA Scale Comps for 4 years with mine, as well as hundreds of trail rides...problem is, you have to build and engineer darn near everything! There is no scale aftermarket support whatsoever. If you love to scratch build and tinker, then go for it! Lots of good info here in the Losi section to make it a success! |
05-26-2015, 09:39 PM | #16 | ||
LNC Run Time - Similar Threads | ||||
matt*strike's LNC first time out | matt*strike | Team Losi Comp Crawler | 7 | 06-15-2012 11:31 AM |
Run time? | Mini Mangler | Electronics | 2 | 02-27-2011 12:05 PM |
Creeper run time vs AX-10 run time | MikeSSS | Electronics | 2 | 09-02-2010 10:47 AM |
run time? | sleek6mt | Tamiya Clod Buster | 2 | 03-13-2006 06:04 PM |
Run Time | BlackSheep | Tamiya Clod Buster | 17 | 07-10-2005 08:37 AM |
