Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Billet works designs front battery tray
Old 06-27-2015, 11:53 AM   #1
Default Billet works designs front battery tray
I was wondering if anyone here has ran the billet works designs front battery tray ? Here is the link
LCC/LNC Servo/Battery Mount Aluminum - Billet Works Designs
I picked one up for my night crawler and it will not fit due to the shocks being in the way. It is advertised for a nc/cc but does not fit with the nc style upper shock mounting. I have been wanting to convert to the c.c shock mounts so I can ditch the top plastic tray. Any info is appreciated.
Thank you
horsinaround is offline   Reply With Quote
Old 06-27-2015, 03:22 PM   #2
Default Re: Billet works designs front battery tray
Thank you
I have the BWD plate on both my rigs,-but with Traxxas Big Bores.
With the XR10 chassis,the angle of the shocks are different,-so no problem:
With the Sucker Punch chassis I moved the shocks down together with the link mount:
JENS is offline   Reply With Quote
Old 06-28-2015, 08:11 AM   #3
I don't know what the originally designed it for. I assumed a stock chassis when I ordered it. The website didn't say otherwise. I am hoping it will work with the comp crawler shock mounts but I don't think so. I sent them a email so hopefully they respond soon. You would think if it wouldn't work with a factory chassis they would say that on the website.
Sent from my XT1080 using Tapatalk
Old 06-28-2015, 09:16 AM   #4
Looks to me like they moved the wheels out with spacers to get that plate to clear on a hard turn
crashtestheli is offline   Reply With Quote
Old 06-28-2015, 09:16 AM   #5
You can't bolt the shocks up with the plate on.
Old 06-28-2015, 10:37 PM   #6
mbc
I use their tray as well. But i have a fastback chassis and no problems with fit. Looks to me that the rig in the picture has one of their aftermarket chassis. Oh and adding wheel spacers was a key upgrade for clearance. The wider stance sure helped on the rocks as well!
mbc is offline   Reply With Quote
Old 06-29-2015, 03:11 PM   #7
I missed the part in crashtestheli's post were he said the spacers make it clear on a hard turn. I agree with you guys. I am sure they are needed. Who is a good company to get spacers thru ?
I was hoping to use this plate with a factory chassis for now. How hard is it to modify a axial based chassis like the fastback to work ? Do you use the losi trans or the axial ?
Old 06-29-2015, 03:54 PM   #8
Mbc would you mind posting some pictures of your rig ?
Old 07-07-2015, 12:31 PM   #9
mbc
I use the junfac +13mm wheel spacers and stock lnc axles. I had no problems getting the fastback chassis to fit the lnc tranny. Juan at UGC offers the skid drilled for axial or blank. I got blank and drilled my own holes.
Sent from my LG-D415 using Tapatalk
Old 01-21-2016, 07:55 PM   #10
It's made for ax10 axles w/ xr10 mod
Nburns11 is offline   Reply With Quote
Billet works designs front battery tray - Similar Threads
Billet Works Designs Prototype Tricopter billet works Non Crawler RC's 64 05-31-2012 04:26 PM
Welcome to Billet Works Designs billet works Vendors Market 67 05-16-2012 11:53 PM
Billet Works Designs U-Dig...something new from my lab billet works Axial AX-10 Scorpion 162 03-22-2011 09:04 PM
