Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Level3rc
Old 10-03-2015, 07:55 PM   #1
Default Level3rc
I bought a steering link for my LNC on sept 11th received it on the 15th defective contacted the seller said they would send a new one out a week goes by no link contacted them again o sorry we will get one out in the am & provide a tracking# another week nothing no tracking # great customer service I told them to just keep it I will never deal with level 3 rc again what a shame.
Rolin Roc is offline   Reply With Quote
Old 10-04-2015, 12:59 AM   #2
Default Re: Level3rc
What was wrong with it? I got one from them as well, it was fine but needed some work to get it to work and had more toe then stock but other then that, you get what you pay for.
There's a few other options you can do for a stronger steering.
84yoda is offline   Reply With Quote
Old 10-04-2015, 01:13 AM   #3
MODERATOR™
EeePee's Avatar
Little research would tell ya, garbage.
Shouldn't have "work" on it.
EeePee is offline   Reply With Quote
Old 10-04-2015, 06:32 AM   #4
Yeah found that out i'll pick up a used lcc steering link & be done with it.
I don't mind having to work on parts to make them work had to do that a lot on m 5t it came down to principal I don't like to be circle jerked from a sub manufacture.
Old 10-04-2015, 12:53 PM   #5
I bought new plastic ends and 100mm titanium link from VP and works awesome and cheap.
Old 10-04-2015, 01:35 PM   #6
Thanks 84 I just picked up a used LCC steering link set up in good shape
I already built the 4 links it's turning out good can't wait to run it .
Old 10-04-2015, 11:42 PM   #7
Did you get straight or bent in rear? If you didnt get bent ones, pick up some rear bent ones from dlux, huge improvement then standard straight ones. Straight is fine for front.
Old 10-05-2015, 05:46 AM   #8
Yeah I got the straight I'll have to check those.out thanks
Old 10-05-2015, 03:21 PM   #9
If your goin to order some from him, make sure to order front lowers off his site. His front lowers are bent and stock length (but you will run in rear). If you were to order rear lowers, they are bent but longer to extend wheelbase and if your running a lnc then you cant extend wheelbase because of the driveshafts.
Old 10-05-2015, 04:10 PM   #10
Got it thanks for the tip much appreciated!
Level3rc - Similar Threads
level3rc desertdude Axial Wraith 5 01-20-2015 09:02 PM
level3rc motor mount mini freak HPI Wheely King 4 07-29-2011 06:12 AM
