04-04-2016, 01:47 AM | #1 |
Rock Stacker Join Date: Mar 2013 Location: ENGLAND
| motor/ gearing for a losi comp
bought some losi comp running gear recently and im building a sportsman with it. theres no info really in the uk on losi's so ive come here for help. what kv motor do i need to be looking at and what pinion. Adam |
04-04-2016, 05:05 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: motor/ gearing for a losi comp
With an LNC tranny, I am running a sensored 13.5 on a 3 cell, and I think a 14T pinion.
04-04-2016, 08:12 AM | #3 |
With the LCC tranny you must use smaller pinions. Pinions 12-15T is a good range. Motors... Brushless two-poles in the 13.5T - 17.5T range depending on battery voltage is the cheap option. Any Tekin ROC412 or Holmes Hobbies Revolver S are premium options. (I use a Revolver S Stubby to save weight.) Running the LCC as a sporty you should remove the dig forks to reduce friction. (Read my friction thread to learn more.) |
04-04-2016, 10:14 AM | #4 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
I run a 21.5 with high torque rotor and a 12t pinion. 4s battery with mmp cheat (boost) enabled the last 25% or so of throttle pull.
04-05-2016, 01:27 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Tekin roc 412 3100kv on 3s, 20t pinion with lnc tranny here. HH puller pro stubby is a good option, I want to try one out.
04-05-2016, 01:52 PM | #6 |
Quarry Creeper Join Date: Dec 2013 Location: San Diego county
i run a novak 18.5t with a 20t pinion on 3s with an LNC trans, works great
04-05-2016, 03:15 PM | #7 |
Cheers for the advice. Has anyone tried using an outrunner in one? I know they can cog at low speed but with the worm gear ratio id have thought it would take that out?
04-05-2016, 05:49 PM | #8 |
i know its been done, quick search brought this one up YB's outrunner sportster |
04-05-2016, 05:50 PM | #9 |
i have been tossing the idea of building an outrunner rig out of my extra losi axles.
04-06-2016, 12:33 AM | #10 |
im on the look out for a 13.5t motor second hand in the uk if i cant find anything il give it a go. the rig is only for a bit of playing as there are no 2.2 comps over here anymore
04-06-2016, 05:48 AM | #11 |
| Re: motor/ gearing for a losi comp |
04-06-2016, 06:26 AM | #12 |
04-06-2016, 02:55 PM | #13 |
Yeah I've heard good stuff about them and eager to put one in a build but the cost to get one yo the uk gets crazy :-(
04-07-2016, 10:45 AM | #14 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I've been having quite a bit of success with big Un-sensored Outrunner as a direct drive setup. My latest C3 scaler only weighs 4.1lbs I'm using a Turnigy 850KV motor with a Castle Sidewinder Micro ESC on 3S. The vehicle is AMAZING. |
04-07-2016, 11:43 AM | #15 | |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: motor/ gearing for a losi comp Quote:
Performance videos? | |
04-07-2016, 12:04 PM | #16 |
| Re: motor/ gearing for a losi comp yeah im in for some more info as well, low speed cogging, downhill performance? i agree any videos?
04-08-2016, 12:23 PM | #17 |
I'm going to try out an outrunner going lower kv abd bigger pinion
04-08-2016, 03:41 PM | #18 |
Here are a few videos of my new C3 in testing. Disclamer: My 7 year old son was videoing! might be shaky! Lol All running Losi axles with HD Front / Stock rear Castle Sidewinder Micro and 3S Turnigy 810KV (G15) OutRunner <iframe width="560" height="315" src="https://www.youtube.com/embed/IKBZWz9jiQQ" frameborder="0" allowfullscreen></iframe> <iframe width="560" height="315" src="https://www.youtube.com/embed/kOsK-SZd1lw" frameborder="0" allowfullscreen></iframe> <iframe width="560" height="315" src="https://www.youtube.com/embed/wz87HpyIHAM" frameborder="0" allowfullscreen></iframe> EDIT: Dont know why video not popping up. Here is another link below. https://www.youtube.com/watch?v=IKBZWz9jiQQ https://www.youtube.com/watch?v=kOsK-SZd1lw https://www.youtube.com/watch?v=wz87HpyIHAM Last edited by GiJoe; 04-08-2016 at 03:45 PM. |
04-08-2016, 03:56 PM | #19 | |
Its not expensive at all! I think these Turnigy motors are like $30.00 Shafty comp could probably work...Its not the smoothest setup. But i have found with the ESC setup correctly and a linear throttle curve, these big outrunners are not terrible by any means. Because these motors are inexpensive, I recently bought and installed an 1100KV motor. I havnt taken out on the rocks / trail yet due to work and weather, but preliminary garage testing is VERY PROMISING! Wheelspeed is fantastic! The other benefit to me is light weight! If you all are familliar with a typical SORRCA Based Class 3 Scaler, the average weight is about 8 lbs. My rig (with -37 scale points) RTR is currently 4.1 lbs!!!! | |
04-08-2016, 04:01 PM | #20 | |
Low speed cogging is not terrible. Its actually VERY Drivable! There is a bit of a learning curve, however, with the ESC setup with standard Linear throttle, its all in the trigger! Once your rolling, it'll creep pretty well. As far as downhill? Definitly not as smooth as a sensored brushless, but again, easy to overcome. | |
motor/ gearing for a losi comp - Similar Threads | ||||
losi comp need motor advice ... | itsonlysir | Virginia | 2 | 06-14-2014 01:25 PM |
Losi Comp Crawler motor | jason7395 | Team Losi Comp Crawler | 2 | 02-20-2012 07:34 PM |
Losi Comp motor/esc combo | Rock Soldier | Newbie General | 1 | 07-20-2011 04:28 PM |
Gearing For Losi 1/10 Comp Crawler Race Roller | Lexar | Team Losi Comp Crawler | 7 | 04-03-2011 08:53 PM |
Losi Comp Crawler Motor Choices | KennyG | Team Losi Comp Crawler | 21 | 09-26-2010 12:31 AM |
